Planars & Exotics ESL's, planars, and alternative technologies
Monsoon Planar Media 9 Audio System .Speaker Replacement
Old 24th August 2012, 03:16 PM   #51
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
During cleanup i set out the Monsoons (from the box of what should be working ones). Media 7 & 9 woofers/amps, 2 MH502 sats for Media 7, 8 planar sats for Media 9. 1 controller (i'm guessing it is a working one)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th August 2012, 07:40 AM   #52
thoglette is offline thoglette  Australia
thoglette's Avatar
Default Planar 9 puck
Originally Posted by bachfan77 View Post
planar media9 issue: can this play without the control puck? I opened the sub; fuse looks good still nothing; hook up the speakers to the sub with headphone plug to computer/iphone nothing? any ideas- really would love to get this working again.
The puck has both the volume control and the mute circuit.
IE the signal goes out to the puck and back again - the mute provides a DC signal to turn the amp on and off. (IIRC it's 5V for on, 5V off - but don't quote me).
If you can't find a puck I'll buzz mine out - I very much doubt there's anything active in it other than the LED - just two pots and a switch.
Old 28th August 2012, 07:57 PM   #53
bachfan77 is offline bachfan77  United States
Default thanks for that
So; I read that if you connect the two speakers to the bass module and run the headphone jack to your computer you'll get sound. I tried this with no success; David- I will be ready to proceed shortly have your returned from your trip.
Thanks!
Old 29th August 2012, 02:34 AM   #54
thoglette's Avatar
Default System 9 de-pucked
No - the System 9 puck has a mute function which turns off the amplifiers and the audio goes via the puck. No puck, no noise.
The MH-502 puck is just an in-wire volume control between the source and the amplifier system. It can be bypassed completely.
Old 29th August 2012, 12:18 PM   #55
understand; hopefully planet10 can hook me up
Old 30th August 2012, 01:51 AM   #56
thoglette's Avatar
Yup - took mine apart last night and there's a lot more in there than I expected. Lots of passives and an 8pin IC (dual op amp?)
Photos later
Old 30th August 2012, 12:37 PM   #57
thoglette's Avatar
Default System 9 puck
Photos later
Top and bottom of puck
Old 30th August 2012, 12:50 PM   #58
the puck I have is fine it is the other end which plugs into the sub is destroyed
Old 30th August 2012, 02:42 PM   #59
thoglette's Avatar
Default Jesus, Mary and Joseph!
Ah, well, that'll be the problem then!
The connectors are a dime a dozen MMSC 8-pin Mini–DIN Connector. If yours is completely banjax I can buzz out mine from the connector on the PCB to the mini-DIN
Old 30th August 2012, 02:59 PM   #60
appreciate you willingness to help; however it appears that the cable is available however when you trace the cable to the control center it appears to be soldered into the board; so leads to the question how does one use a different cable to connect?
Monsoon Planar Media 9 Audio System .Speaker ReplacementHide this!Advertise here!
Monsoon planar drivers - has anyone used 'em? Spasticteapot Planars & Exotics 16 21st May 2012 01:22 PM
monsoon planar media 7 as line array vmps Planars & Exotics 24 5th September 2009 05:23 PM
monsoon planar computer spkrs capt mike Planars & Exotics 4 29th July 2008 09:05 AM
Small Monsoon-planar speakers - any help! Spasticteapot Multi-Way 0 5th January 2007 07:23 PM
impedance of monsoon planar 9 panels knifeinthesink Planars & Exotics 0 6th August 2006 10:59 PM
Copyright ©1999-2017 diyAudio
