Planars & Exotics ESL's, planars, and alternative technologies
B&G RD-75 dipole - baffle and or waveguide?
Old 4th October 2012, 07:41 PM   #131
StigErik is offline StigErik  Norway
StigErik's Avatar
Originally Posted by Vadim View Post
Yes, I understand and I agree that you can do without a baffle, as long as you are willing to live with rather high roll off. I wanted to use 10-inch drivers for my mid-range, so at most I needed to place the crossover around 500 Hz and my baffle can support that. You probably are using 8-inch drivers.
Erik, I wonder if you could describe your PC-based crossover in some detail. I would like to know what software you are using and what are the computer requarements? Also, - how many channels are possible? Am I to understand that you are running multiple SPDI/F outputs out of your PC? Can you do AC-3 5.1 format? I just might go the same route. Thank you.
At my listening distance, RD-75 is flat to 200 Hz even with no baffle. I XO at 180 Hz. The real attraction with the RD-75 is that you can make a 2-way.
I am using 21" woofers in large H-baffles together with the RD-75.
My PC XO is based on a midi routing software called "Console", which can be used as a host for VST-plugins. I use a high-quality parametric EQ plugin for both XO and EQ. Such a system can do multi-channel, provided you have enough outputs. A three-way 5.1 system will require 16 channels. Some pro-audio interfaces can support that through AES-3 or ADAT interfaces. How powerful the computer needs to be depends entirely on what EQ plugins you will use. Some are quite CPU-intensive, and some are not.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 12th October 2012, 10:43 PM   #132
maestrok1 is offline maestrok1  Canada
Smile Questions
Hi StigErik I have a few questions I would like to ask you. I just ordered the Bohlender Graebener RD75, they should be here in a week. My questions are at what frequency on the top end do I need to start EQing from. I know it's 12dB at 20khz but were does compensation start at. Also at what exact frequency do you need to compensate with a notch filter and how wide of band, I guess that is the Q. I am using a active crossover Marchand xm44, so not digital. I need to order the frequency modules for this crossover. Thanks alot.
Old 17th October 2012, 12:15 PM   #133
StigErik's Avatar
Main EQ points that I use are:
20 kHz, +10 dB, Q=10
5800 Hz, -4,5 dB, Q=1.6
Note that the 5800 Hz EQ may not be correct in every case, as the baffle shape and size changes the response peak to a certain degree. To be sure you should have them measured.
Old 17th October 2012, 09:31 PM   #134
I was wondering if you could change the q figures into frequency response for me. I don't know how q works. Is a q of 10 one octave. Also if I give you a baffle width of 20 inches could you calculate the notch filter frequency for me, I don't have any measuring software or hardware and probably won't for another 6 months.
Old 17th October 2012, 09:55 PM   #135
StigErik's Avatar
Q is the inverse of octave width. Q=1 is one octave. Q=10 is 1/10 octave.
Old 19th October 2012, 07:04 PM   #136
StigErik's Avatar
Oooops... the EQ values I posted was wrong!
Correct values:
20 kHz, +10 dB, Q=2.5
Like to add that the 20 kHz EQ is really not necessary. I cant hear 20 kHz.....
Old 20th October 2012, 03:04 PM   #137
twest820 is offline twest820
For which definition of bandwidth? With the usual -3dB points it's
Originally Posted by Robert Bristow-Johnson
The relationship between bandwidth and Q is
1/Q = 2*sinh(ln(2)/2*BW*w0/sin(w0)) (digital filter w BLT)
or 1/Q = 2*sinh(ln(2)/2*BW) (analog filter prototype)
You can find the Bristow-Johnson cookbok here.
Most software implementing digital filters takes analog values as input and uses the same definitions as Bristow-Johnson. So generally one wants the analog translation for converting from Q to bandwidth in octaves to find the values to plug into the UI:
BW=2/ln(2)*asinh(1/(2*Q))
Old 20th October 2012, 10:03 PM   #138
Smile Double check
Stig Erik are these frequencies correct. A notch filter frequencies of 5800hz wit a q of 1.6 gives me a starting frequency of 3625hz and an ending frequency of 9280hz. Is that correct? That seems like pretty big range for a notch. Just figured I'd double check. Thanks alot StigErik.
Old 21st October 2012, 07:39 AM   #139
StigErik's Avatar
This is how such a notch looks like in a parametric EQ.
Old 25th October 2012, 01:13 AM   #140
Will the notch be more than 4.5db when installed on a baffle instead of the round overs you used on your drivers.
B&G RD-75 dipole - baffle and or waveguide?Hide this!Advertise here!
Waveguide loaded MT dipole? mayhem13 Multi-Way 14 3rd August 2010 02:13 PM
OB MTM w/ Dipole Waveguide thadman Multi-Way 12 10th February 2010 08:56 PM
75 degree waveguide, any good reason? dantheman Multi-Way 16 3rd January 2010 04:52 AM
BG-75 / ATC planar dipole construction auplater Multi-Way 8 5th February 2007 03:00 AM
open baffle bass-dipole-what amp felixx Multi-Way 20 13th December 2006 07:53 AM
Copyright ©1999-2017 diyAudio
