Planars & Exotics ESL's, planars, and alternative technologies
ESL Mylar stretching Tension
Old 2nd May 2011, 06:54 AM   #1
Arno Pf is offline Arno Pf  Netherlands
Default ESL Mylar stretching Tension
Wat tension is correct when stretching the mylar foil?
My two full range ESL's differ in SPL whereas the resonance frequency is comparable (coating is 100% ok). Compensating with Bias voltage works but it still puzzles me if it is better for a full range ESL to have a low tension and a lower bias voltage to avoid sticking to the stators.
What is your experience in this?
Thanks in advance,
Arno
Old 2nd May 2011, 08:59 AM   #2
markusA is offline markusA  Sweden
markusA's Avatar
From what I've read on this board I think 2-4% stretch is appropriate.
I'm gearing up for my first build myself so I can only repeat what I seem to remember reading.
Hopefully you can get some better advice from people with real experience.
It'll be interesting for me as well.
Old 2nd May 2011, 11:28 AM   #3
MJ Dijkstra is offline MJ Dijkstra  Netherlands
Thanks in advance,
Arno
Hi Arno,
Could you check the drive voltages of both esls?
To answer your question; lowering bias voltage will decrease efficiency. Rob de Lugt (audio4) once made a very wide esl bass panel with rather low polarization voltage. The result was amazing low bass but at very low soundpressure as well
drs M.J. Dijkstra
ESL Mylar stretching TensionHide this!Advertise here!
Who sells mylar for ESL 57 ? Fabien Lefebvre Planars & Exotics 5 6th March 2010 08:42 PM
stretching Mylar for curved ESLs, How? MJ Dijkstra Planars & Exotics 4 7th June 2006 06:34 AM
ESL: Mylar 4 micron vs Polyester 3.8 micron michaelpage26 Planars & Exotics 12 26th July 2005 12:43 AM
Source for ESL Mylar in Canada Zenith_Nadir Planars & Exotics 4 10th June 2005 05:10 PM
Copyright ©1999-2017 diyAudio
