concept spk.ce-m with heil 1978 concept spk.ce-m with heil 1978 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 19th April 2011, 12:54 PM   #1
audioray is offline audioray  United States
Default concept spk.ce-m with heil 1978
CONCEPT CE-M any info on these speakers from 1978. they are big 45h-18w-15.5d.
14.5 passive-12woofer-heil on top.they use all ess drivers. the front baffel
is sloped they are beautiful.im thinking of making a clone.just need a 15"
passive radiatior. any input appreceited.
Old 19th April 2011, 01:10 PM   #2
Default these are the concept spk.
http://www.sportsbil.com/concept/speaker-brochure.pdf
Old 24th June 2011, 08:42 AM   #3
el seven is offline el seven  United States
I own this same pair.
Profound sonically and the cabinets are truly monsters.
Old 24th June 2011, 07:58 PM   #4
Default ess1am
hi
when did you buy them.
i have ess1a-m that iby amp with ess x-over at 800hz.
when i saw the cm ihad visions of making a clone.
i just re-capped my xovers they still soud xciting after 40 years.
do you have photo with covers off. trying to see what top looks like
thank you
Old 25th June 2011, 09:43 AM   #5
no photos but i received them from their original owners where they were used in a demonstration in 1976 or thereabouts and then clearance-sold as not new.
they look just as the pdf you posted and i'm in need of radiator units so i'm afraid i will have to build them myself. i don't play them as a result of this. can't expect to find loose parts like this anywhere either, especially at ess it's own self since they're so disorganized and caddywhompus in the facility.
Old 26th June 2011, 01:51 PM   #6
Default ess ce-m
i just turned big 70. been with audio sinch 1962 with KLH early days.
did ESS build these speakers way back then. i saw some big passive at
parts express i think they were 15". my idea of a clone would be a
founteck 5" ribbon/fostex168/focal 10"woofer 10v516 with a power plate/12"dayton12"passive
wich i have on hand.would it work ?????????.
chow.
concept spk.ce-m with heil 1978Hide this!Advertise here!
Rebecca (1978) Simon Langton A3rd.Zero Everything Else 2 28th May 2014 06:49 PM
1978 Radio Shack catalog gain wire Everything Else 16 9th December 2010 06:54 AM
Norman laboratories model 8 (pair) 1978 sid6point7 Swap Meet 1 4th December 2010 01:08 PM
Replace the field coil spk with Electromagnetic dynamic spk pioneervn Tubes / Valves 6 3rd July 2005 03:48 PM
vintage chipamps circa 1978 lumberdust Chip Amps 1 17th January 2005 07:03 PM
Copyright ©1999-2017 diyAudio
