Planars & Exotics ESL's, planars, and alternative technologies
ESL safety protection.
Old 8th April 2011, 06:19 PM   #1
M Gregg is offline M Gregg  England
Default ESL safety protection.
Just a quick question,
The stator of the ESL is powder coated or painted.
How do you ensure no contact with the stator voltage?
The two outer plates are at B+, are we just relying on the powder coat?
M. Gregg
Old 8th April 2011, 06:49 PM   #2
geraldfryjr is offline geraldfryjr  United States
Yes ,unless you build a frame and supports for a protective insulating screen of some sort. jer
Old 8th April 2011, 07:07 PM   #3
Is this also the case with ESL like martin logans? IE do they rely on the powder coat? I guess an isolation Tx for the B+ may help?
M. Gregg
Old 8th April 2011, 08:18 PM   #4
The last time I saw one up close I don't recall seeing any extra type of external protection system although I did not risk touching the stator with the my hands flat on each stator while they were operating to find out either.
I have touched mine with the the bias supply on before only when there was a leakage did I get zapped.
I have accidently touched a bare wire feeding my panels A few times and got zapped pretty good.
But this is not a practice that I would recommend by any means.
I hope that helps. jer
Old 12th April 2011, 03:24 PM   #5
lcsaszar is offline lcsaszar  Hungary
M. Gregg
Are you talking about the Quad ESL (aka ESL-57, although Quad themselves never used this designation)? The stator is driven push-pull by the input transformer with GND reference, and the diaphragm is at HT, not the way around. I think other electrostatic loudspeakers operate on the same principle.
Old 12th April 2011, 09:11 PM   #6
kavermei is offline kavermei  Belgium
kavermei's Avatar
Send a message via MSN to kavermei
Only when the speaker is driven by a so-called direct-drive amplifier, would there be a DC voltage on the stators. That's about 1% of the products out there, and here is a real danger if the stator insulation is damaged.
In the other 99%, there will be no DC voltage on the stators. Still, unless you trust the insulation, you shouldn't touch one stator with the right hand and the other with the left while music is playing.
Kenneth
Never send a human to do a machine's job. --Agent Smith
Old 12th April 2011, 09:28 PM   #7
Thank's for the answers,
Just a quick question is the performance effected if the holes in the stator are square and not round?
I ask because it seems the steel plates with square holes have a higher percentage of air to metal. IE more holes to the inch.
M. Gregg
Old 13th April 2011, 07:50 AM   #8
Calvin is offline Calvin  Germany
Calvin's Avatar
This can be true, but in some cases it is not. Either a DC-blocking cap in the ampīs output or dual supplies are a measure against DC-potential on the stators. The Acoustat used a DC-blocking cap for example.
jauu
Calvin
Old 15th April 2011, 08:19 PM   #9
kavermei's Avatar
Hi Calvin,
I wouldn't consider cap-coupled to be direct drive any more than transformer coupled... You are right about the case where you have dual supplies, of course.
Kenneth
ESL safety protection.Hide this!Advertise here!
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 30th July 2014 12:14 AM
safety - esl with kids rbmcginnis Planars & Exotics 7 12th May 2007 01:15 AM
Dutch ESL builders attention...part ESL for free Bas Horneman Swap Meet 10 14th June 2005 08:54 AM
Copyright ©1999-2017 diyAudio
