silver foil caps for ribbon membrane
Well, IMO ,go for price per (/) material volume per (/) field strength vs surface area /
I hope I (said that right)
I figured out a formula for capacitors aswell.
farads / voltage / price
The lower the better.
Been a while since I figured that one out
Anyway the most density for the price of course.
stacking them is like putting batteries in series .jer
i just found a product that may be of interest for making diaphrams
Chemtronics | Workshop Consumables | Adhesives, Sealants and Tapes | PCB Compounds and Adhesives | Conductive Adhesives-PCB Compounds and Adhesives |CW2900
it is a conductive silver paint pen ,it could be used to draw nice tracks on a mylar ribbon from top to bottom instead of glueing aluminium to the maylar
heres another
RS | Workshop Consumables | Adhesives, Sealants and Tapes | PCB Compounds and Adhesives | Conductive Adhesives-PCB Compounds and Adhesives
if conductive enough you could simply lay out your mylar and draw your tracks top to bottom ,it would only work for a segmented ribbon though and i,m not sure how it would hold up to corrigating
cheers sheafer
I have not yet actualy used any gorilla glue yet for a few reasons ,but I am about to embraqe on the ups and downs of such a product.
I would like to come up with a process to be able to use it without the foaming.
In ESL's the air bubbles can cuase a weakness of the dielectric material in the area that it is tyring to seal from the electric field.
Especialy when you are talking about 27Kv peak to peak across the stators. jer
I did try using conductive silver paint on some polyester leader tape.
Altough my technique could have been improved it was a rather messy and I wasted quite a bit of it.
It did add considerable mass and when I tried to corragate it ,it just peeled.
It seem be some sort of silcone type base as it was soft and rubbery.
With the plating method with copper, I found it difficult to get a consistent thin coating.
The copper was very pure and brittle and cracked when you looked at funny.
It had surface that resmebled sandpaper I'm sure this had alot to do with the base coating aswell.
Not to mention that it's final mass was to high to be usable.
So I gave up on that idea.
Then I had aquired some aluminized 1/4" mylar ribbon that is used for party decorations.
It also as a high resistance of about 50 ohms to 100 ohms per foot.
I wil have an exact measurement for you tomorow as I have miss placed my meter(it is in the gerage and it is raining).
Because of the resistance factor I have not yet tried it.
I am wondering If using a step up transformer would compensate for this?
Another method (in the back of my mind) would be to electroplate a thin layer of copper on it.
But in the long run there are problems of the copper and aluminium reacting with one another. jer
Here some great threads to read,only a start.
Such a wealth of information and probably an answer for every question one might have, from making transformers and ribbons to magnet types and structures and my favorite,how to calculate effeciency. jer
http://www.diyaudio.com/forums/planars-exotics/50162-another-diy-ribbon-thread.html
http://www.diyaudio.com/forums/plan...-tl-loaded-extremis-hybrid-4.html#post1532031
http://www.diyaudio.com/forums/planars-exotics/130733-diy-ribbon-construction-steele.html
http://www.diyaudio.com/forums/planars-exotics/125791-diy-70-ribbon.html
