Planars & Exotics ESL's, planars, and alternative technologies
How to make a good transformer for ribbon tweeter?
Old 7th March 2011, 03:58 AM   #21
geraldfryjr is offline geraldfryjr  United States
It all depends on the wire gauge you use and and length of the wire used to get your selected turns ratio.
There are many ways to combat this ,from wire size to multiple windings in connected in parallel.
The latter being more ideal as this would increase core coverage and reduce the leakage inductance.
For practicablity reason by using multiple windings in parallel, the DCR of transformer should be much less than the ribbon itself, not to mention the DCR of the transmision line feeding the ribbon from the transformer as well.
jer.
Old 7th March 2011, 06:20 AM   #22
miklos is offline miklos  Hungary
miklos's Avatar
Originally Posted by bear View Post
Ur missing the part where the DCR of the secondary becomes many times that of the ribbon.
Not, since you winding your own secondary.
miklos
Old 7th March 2011, 02:52 PM   #23
bear is offline bear
expert in tautology
bear's Avatar
Using what?
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 8th March 2011, 07:35 AM   #24
Most of us don't use garden hoses.
But that is about the right guage!
I would try (DIY) many many layers of aluminium or copper tape that you can find at your local hobby shop or hardware store.
Laminated with an insulating material like polyurethyn or something.jer
Old 8th March 2011, 01:51 PM   #25
expert in tautology
bear's Avatar
You'd need a pretty tiny toroidal power transformer?
_-_-bear
_-_-bear
Old 8th March 2011, 03:57 PM   #26
why would it have to be tiny?
Old 9th March 2011, 01:32 AM   #27
expert in tautology
bear's Avatar
It is a tweeter transformer?
You don't need huge inductance... etc...
_-_-bear
_-_-bear
Old 9th March 2011, 02:55 AM   #28
Okay,what is your point ? use less turns.
Old 9th March 2011, 02:40 PM   #29
expert in tautology
bear's Avatar
Maybe I am missing something... no matter.
I want amorphous cores and good coupling between windings... LF response is of no interest. Since the secondary is few turns, that is why copper foil is used and not just a handful of turns of say 8ga. At least this is what I am told, having not made one myself.
_-_-bear
_-_-bear
Old 9th March 2011, 05:09 PM   #30
You seem to be understanding okay.
Just remember all of the same rules apply.
the larger the core ,less turns on primary(as per lowest frequency),therefore a lower overall DCR.
one reason for using a flat conductor as a winding is to increase core coverage to lower leakage inductance.
This where I had left off in my study due to equipment failure as I was pushing everything past a pheasible limit.
I had figured out that by just by spreading out the 10 turns of wind reduced the leakage inductance greatly.
And even more so when I used 4 10 turn windings in parallel to get complete coverage.
It was bolsert that told me that if you double the winding coverage you will half the leakage inductance.
I had found this to be true and I had planned to show this when I had burned up my last meter due to the highvoltage rf caused by the crossover distortion of the amp, in combination with the leakage inductance and transformer capacitance causing it to resonate,basicaly forming a tesla coil.
There is some info on using amorphous cores at 6moons.com . jer
How to make a good transformer for ribbon tweeter?Hide this!Advertise here!
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
looking for good mid woofer to use with Ribbon Tweeter. samsagaz Multi-Way 32 29th October 2004 04:33 AM
good ribbon tweeter caz Multi-Way 5 22nd May 2004 01:08 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
