Planars & Exotics ESL's, planars, and alternative technologies
How to make a good transformer for ribbon tweeter?
Old 26th January 2018, 08:25 PM   #231
lowmass is offline lowmass  United States
Thanks Fooey, very interesting wind.
My own foil sec transformers are similar BUT not exactly the same. On mine I am winding primarys in between each layer of secondary foil BUT I am not soldering the edges together to encapsulate as you are.
I wonder at audio frequency how much the encapsulation is doing??
Old 27th January 2018, 11:44 AM   #232
alexberg is offline alexberg
alexberg's Avatar
Proper HF transformer is a transmission line one, where secondary is a U-shaped piece of copper tubing, primary is wound inside of secondary and the core is a plurality of ring cores put on secondary.
Old 29th January 2018, 02:30 AM   #233
fooeywuffle is offline fooeywuffle  United States
fooeywuffle's Avatar
I would say, the totally enclosed doesn't do much until the frequency is at upper part where stray inductance and not unity coupling of primary to secondary can cause loss. Need really good coupling at the low impedance of ribbon, so enclosing it gets rid of most stray since coupling is very close to perfect. Only resistance loss is left. Tests on them show 8 ohm at 20 watts, 2K to 50K. I have no way to test beyond that, and I can only hear up to 12k anyway. I don't have any reason to make and test any other transformers since these work perfectly. Made 4 of them, and at 70 years old, just don't have the time. Would rather make more amps. It is similar to transmission line one, just 4 of them in series. Could make one like the Balun shown, but sure would take a lot of high Mu toroid's.
How to make a good transformer for ribbon tweeter?Hide this!Advertise here!
Why not a ribbon tweeter instead of a horn tweeter? Curly Woods Full Range 9 15th July 2009 04:09 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
looking for good mid woofer to use with Ribbon Tweeter. samsagaz Multi-Way 32 29th October 2004 04:33 AM
good ribbon tweeter caz Multi-Way 5 22nd May 2004 01:08 AM
Titanium tweeter vs Ribbon tweeter goldyrathore Multi-Way 14 17th May 2004 07:21 PM
