Planars & Exotics ESL's, planars, and alternative technologies
Acoustat Answer Man is here
Old 30th November 2017, 12:41 AM   #1871
JAHM is offline JAHM  New Zealand
Here - hopefully - are three images of sections of my right-hand channel Spectra 6600. If they don't appear, I might have to ask for assistance on how to upload images. These ones are on my Google Drive.
Old 30th November 2017, 01:35 AM   #1872
Sadly. that wasn't a success. Don't 'Click the image to open in full size". You'll be waiting ages for them to appear - if they ever do! Unfortunately, I neglected to create thumbnails so I'll try that next.
Old 30th November 2017, 02:01 AM   #1873
I've reduced the size of each of the files to 12 percent of that I uploaded earlier and I've uploaded these new images in a new folder to my Google Drive. The original resolution was such that they still look good.
Hopefully, this will produce a more satisfactory result here.
Old 30th November 2017, 02:22 AM   #1874
Curses. I wonder if it might be because Google Drive areas are secure (i.e. https)?
I definitely need some help here. Thanks.
Old 30th November 2017, 02:29 AM   #1875
bolserst is offline bolserst  United States
bolserst's Avatar
This may help...
How to attach images to your posts.
Old 30th November 2017, 08:13 AM   #1876
Originally Posted by bolserst View Post
Many thanks, Bolserst. I previously clicked on the FAQ option and carried out a search for 'Uploading images' but it returned nothing so I didn't look any further. I don't think I would ever have found the answer without your assistance so thanks again. I've printed out the relevant article and will try it out shortly.
Old 30th November 2017, 08:22 AM   #1877
Here are three photos showing my RH channel's SPECTRA 6600s.
Old 25th December 2017, 10:48 PM   #1878
dmoro is offline dmoro
The acoustat 2's I purchased a few years ago Don't have the felt blocks. I probably won't be able
To find a set of 4, so I will try making them. Can someone post the thickness of the felt
And the actual dimentions.
Thanks.
Dave
Old 26th December 2017, 01:07 PM   #1879
AcoustatAnswerMan is offline AcoustatAnswerMan  United States
AcoustatAnswerMan's Avatar
Default Spectra 6600 Factory Photo
I finally had a chance to rummage through my Acoustat files, and found this black-n-white factory photo of a pair of Spectra 6600's. Unfortunately there's nothing in the photo to lend a sense of scale - it would have been better if these had been "lifestyle" shots instead of "glam" shots.
I have some similar photos of other Spectra models if anyone is interested.
Old 3rd January 2018, 08:49 PM   #1880
mraudioguru is offline mraudioguru  United States
Default Help needed for Acoustat 2+2 (MK121-2B)
Hey guys! Need your help. I am trying to replace the old capacitors in my MK121-2A interfaces.
I have (3) total stacked together (see pics). The values I can read are 250V 10uf, 200V .47uf and 27 000 160v that's the little electrolytic cap on the end of the (2) yellow caps.
The schematic I have doesn't show the electrolytic and the .47uf is listed as a .01uf.
What should these values be? And should the electrolytic cap be left off or what should replace it.
I've already changed out the binding posts and old Monster wire and put on longer, bigger gauge AC Power cable.
Thanks for your help!
Acoustat Answer Man is hereHide this!Advertise here!
No answer Antoni D The Lounge 2 13th February 2011 06:19 AM
need a tech to answer this one pks71 Car Audio 1 19th November 2004 11:50 AM
