Planars & Exotics ESL's, planars, and alternative technologies
DIY ribbon info requested (constructing a ribbon unit)
Old 10th February 2011, 11:27 PM   #1
SpinMonster is offline SpinMonster  United States
Default DIY ribbon info requested (constructing a ribbon unit)
I wish to build a 26-36" ribbon like the one here:
"The tall neodymium ribbon". Part 1
I havent built anything like this before so I wish to go ahead with a 1000 dollar project. I am very good at fabricating but I need some tech info.
1-Do I have to use a side by side magnet assembly as he did or can I use a single row of really strong magnets on each side? Can I use a 3 x 1 x 1/2 instead of side by side 3 x 1/2 x 1/4 essentially combining the side by side magnets?
2-Will the use of thicker magnets make it more efficient? For example, Will a 3 x 1 x 1 increase efficiency over a 3 x 1 x 1/2?
3-Can someone explain the orientation of the magnets by poles...IE pos to pos and neg to neg with the magnets pushing away from each other?
4-On this site:
Applied Magnets & WindMax Wind Turbines
most magnets are described as 'magnetized through thickness'. Is this what I need?
I have already made corrigated ribbons using his proceedure for my 5" ribbon tweeters and they sound and measure better than the originals.
I will post pictures and results as I proceed.
Thanks.
Old 11th February 2011, 01:06 AM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
from two construction pictures, I would say yes, magged through thickness
Old 11th February 2011, 01:14 AM   #3
I have marked north and south poles in the picture
I suppose its how it should be
Old 11th February 2011, 01:28 AM   #4
it will be more efficient, yes
Dahlberg's magnets looks like 2" x 1/2" x 1/4"
so the only magnets you should use are 2" x 1/2" x 1/2"
ofcourse they can be longer
but may get so strong they are difficult to handle
note that each side of the magnet system should be assembled to one unit before placing the magnets
though Dahlberg seem to use a neat trick, so that he can rotate each side, to ease the mounting of magnets
but I can tell, be very very careful here
they will clash together at any chance given, and with exstreme force
but could be a very dangerous trick
make no mistake, or your fingers could be crushed, completely beyond saving
it is a very dangerous thing
and even if using very thick and strong iron, the force of the magnets will bend it
hence notice the small brass tubes Dahlberg is using
I will estimate that the combined magnet force could lift a small car
Old 11th February 2011, 01:46 AM   #5
note that increased sensitivity may not be linear
the result is not always better sound
sometimes it just gets more peaked
Old 11th February 2011, 06:55 AM   #6
Thanks for the responses.
It appears that he used a dual magnet configuration to make the magnets more manageable. The pulling force on some of the alternative sizes approach 70lb's. I guess smaller mags and more of them will also resist breaking too.
Old 11th February 2011, 12:48 PM   #7
brunob is offline brunob  Germany
Default Safety
I always wear safety goggles and gloves when dealing with neodymium magnets.
Old 11th February 2011, 12:51 PM   #8
Is there any measurements of the frequency response and sensitivity available for "The tall neodymium ribbon". I did not see any on the website - may be I have missed it?
Bruno
Old 11th February 2011, 03:13 PM   #9
ABJensen is offline ABJensen  Denmark
Bruno
DahlbergAudioDesign
Old 12th February 2011, 09:50 AM   #10
Looks usable from 500 up. I wonder how efficient that one is. Coupled with two free air 12's it should be a pretty good system.
It looks like a 26" would do fine on top end.
DIY ribbon info requested (constructing a ribbon unit)Hide this!Advertise here!
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
Specifications/Feedback requested FTT75 Ribbon Tweeter with Audio Technology bass/mid Adrie Multi-Way 4 20th April 2005 08:07 AM
which 5" unit to fountek jp3.0 ribbon wuffer Multi-Way 34 24th February 2005 06:44 PM
Anybody have any info on Tonigen Ribbon Tweetes? kiwi_abroad Multi-Way 1 17th December 2001 07:49 PM
Copyright ©1999-2017 diyAudio
