Planars & Exotics ESL's, planars, and alternative technologies
Quad ESL 57 panel refurbish: DIY or not?
Old 27th November 2012, 05:18 PM   #31
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
Two years later, I feel very happy using this neon bulbs as indicator.
Last saturday, I found the neon bulbs constantly glowing!
I opened the backcover and found some dust bridges between the psu and the backcover (I did not mould the psu in wax, it is open).
After removing the dust (sorry, I should have made a picture), the bulbs are flashing now every two seconds.
The panels are beginning to leak. I will have a closer look at it soon. Maybe now it's time to refurbish the panels?
Franz
Old 29th November 2012, 10:33 AM   #32
Fabien Lefebvre is offline Fabien Lefebvre  France
Franz
Before re-furbishing everything, if your only problem is some not-severe leakage, you can just remove the dust cover and re-insulate the outter part of the stator with serious tape (black 3M).
Quad fan ! One hobby: re-build ESL 57
Old 29th November 2012, 04:58 PM   #33
Franz Gysi's Avatar
Thanks for this advice, Fabien
You recommended me the same procedure two years ago :-)
I plan to do this during Christmas Holiday.
Franz
/Edit (add a Picture)
Old 29th November 2012, 09:01 PM   #34
You mean you already did that 2 years ago and this happens again ?
Old 30th November 2012, 05:13 AM   #35
Franz Gysi's Avatar
No, I didn't
Old 30th November 2012, 08:29 AM   #36
No, I didn't
So maybe time to try it.
You will probably notice at that time that the current tape which is applied has aged.
Old 30th November 2012, 06:37 PM   #37
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by Fabien Lefebvre View Post
(black 3M).
Can you say more about the Black [magic] tape?
3M has hundreds, maybe thousands types of tape
albert
SPU --> tube MM/RIAA;
Pass buffer -->300B SE Anza´ Za´ka; --> FE103 sigma TQWT
Old 30th November 2012, 08:11 PM   #38
albert
I am using one or two layer of the classical electric black tape (3M) + 2 layers of the thin transparent tape used for parcels.
The black tape covers the rivets themselves, not the sides.
Take care that if too thick, it will be harder to install back in the frame.
Old 1st December 2012, 06:19 PM   #39
Franz Gysi's Avatar
Fabien
I am a happy guy as I got an old spare bass panel some weeks ago. It has severe oxidations and the dustcover is damaged.
I can use this panel to explore the construction in detail before I work on my other panels.
Franz
Old 2nd December 2012, 10:29 PM   #40
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
I have Quad 57's with serial numbers 21258 & 21253. I guess these should have clamping boards for treble units. I have disassembled one speaker for investigation & power plug replacement but cannot see a clamping board anywhere. Is it within transformer casing or its missing?
Lukas.
Quad ESL 57 panel refurbish: DIY or not?Hide this!Advertise here!
Refurbing Quad ESL-57....Some Queries! Fanuc Planars & Exotics 14 2nd January 2012 12:12 PM
QuAD ESL 57 Question dude007 Planars & Exotics 30 5th March 2010 08:45 PM
QuAD ESL 57 Stators/panel - German ?? dude007 Planars & Exotics 7 16th January 2008 03:00 PM
QuAD ESL 57 in a small room? dude007 Planars & Exotics 3 26th November 2007 03:22 PM
Quad ESL-57 (pair) TimA Swap Meet 2 14th November 2005 12:34 PM
