Planars & Exotics ESL's, planars, and alternative technologies
Femm ?? i dont get it what did i do wrong
Old 17th September 2010, 07:32 PM   #1
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Default Femm ?? i dont get it what did i do wrong
well i tried a simulation with femm
magnet N40 from femmas material size 40x10x10 all mm
steel frame 200x10x10 just to see what happens pure iron selected as material.
magnet direction i used 90 degrees but i dont know if this is right with other values things got even more wicked.
well question is why is the flux not at all in the air gap it remains in the iron fully. and i dont get the flux rating from the legenda on the right. look way to hig or am i wrong here.
for the mid piece i slected air, also around the whole procjet i made a rectangular and stated the material whas air.
i used this this from el posted somewhere on the forum
A short description:
File New - magnetic or electrostatic problem
Problem - define units, planar/radial
Grid Set Grid - define grid size (units per dot)
Grid Snap to Grid - defined points are aligned with grid dots
set points (with mouse)
select line icon
define lines by selecting two points
Properties Material Library
select materials by drag and drop to the right side
strange green icon is the material marker
set markers with mouse (better with deactivating snap to grid)
select marker with right mouse button
press blank on the keyboard
dialog opens, let femm choose mesh size is only recommended for air, 0.5mm is good for usual audio devices (you have to draw a frame around everything and label the inside with air)
File Save
yellow botton is for creating mesh, the wheel for calculation and the glasses for viewing
in the viewer press the colour icon and select "show density plot" to get everything nice and colourful
with the line icon you can draw a line and display a graph of the flux density over its length (typically define extra points in the editor before calculation)
press the blue graph icon for showing the graph
exporting pictures is done with Copy Paste
if anybody can help that would be great, cant find any tutorial step by step to desigh ribbing motors
Old 17th September 2010, 07:41 PM   #2
WrineX's Avatar
have to upload the image ofcourse
Old 17th September 2010, 07:42 PM   #3
WrineX's Avatar
whoops not cropped
Old 17th September 2010, 08:20 PM   #4
båndsei is offline båndsei  Denmark
You have to make the magnet direction 0 or 180 degrees in that simm.The arrows must be in the same direction R-L or L-R.
But its not the ideal simm .You should make as a crossektion seen from the end.
Old 17th September 2010, 08:48 PM   #5
WrineX's Avatar
0 or 180 will try that and post result, by the way i only fill in 4 magnets instead of the whole bar. you know why the flux results look so strange ? and crosssection i only saw pictures like this so you can see what the output is over the whole setup. what crossbars do etc. or am i wrong here ?
Old 17th September 2010, 09:00 PM   #6
WrineX's Avatar
ok when i change magnet direction to 0 this is what happens, this ooks like strange.
by the way maybe i have to clear the folowing we look at the fron of the ribbon motor with metal bar that forms soem sort of frame and in there the 4 blocks are the 4 magnets i drawed, i did not enter all of them yet because i wanted to see if it worked.
Old 17th September 2010, 09:01 PM   #7
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
if your magnets and iron have the same measures, 10 x 10, then why do they look different in drawing
did you remember to mark N/S pole orientation correctly
sometimes we know very little, and sometimes we know too much
Old 17th September 2010, 09:01 PM   #8
WrineX's Avatar
ok im getting anoyed by myself for forgetting to attach pictures
Old 17th September 2010, 09:02 PM   #9
WrineX's Avatar
whoops you are right, they should be 4 mm, i screw up there , gone change it quick.
also where can you assign poles??
Old 17th September 2010, 09:16 PM   #10
The arrows shows N/S direktion.And you are right about the problem with wieving the crossbars influence.But i can be done.But maybe the way you do it might be right too. I did not see that depth could be set too.
Femm ?? i dont get it what did i do wrongHide this!Advertise here!
How to use FEMM? Spasticteapot Planars & Exotics 23 11th February 2011 05:44 PM
FEMM woofer magnet design article jayam000 Multi-Way 0 22nd December 2009 04:53 PM
Adding Magnetic Properties In Femm ? valveitude Planars & Exotics 2 25th July 2005 04:41 PM
FEMM needed Peter M. Multi-Way 7 7th May 2005 04:46 AM
..woops... posted wrong, dont read contrapasta Everything Else 7 23rd March 2002 08:19 AM
Copyright ©1999-2017 diyAudio
