Planars & Exotics ESL's, planars, and alternative technologies
Planar speaker - first try
Old 29th October 2012, 10:13 AM   #171
JAMESBOS is offline JAMESBOS  England
Am rebuilding a double diaphragm design at the moment, it wasn't very sensitive, and I did use 100 um polyester. I'm glad I use 12 um now, makes a big difference.Laying in bed this morning thinking about the design of my new project, building a very baby grand piano shape speaker using small neos. Especially for playing solo piano music. Will only need one as the piano is not in stereo. The sun is shining, so I had better get outside and cut some more MDF. BEFORE IT RAINS.
HENRY
Old 3rd November 2012, 12:48 PM   #172
Default REPAIR TO BROKEN 3 MM TAPE ON DIAPHRAGM
First picture shows where I broke the tape, and I have put tape for penny washer. 2nd pic shows penny washer in position with wood surround for holding diaphragm in tight and correct position. 3rd pic shows diaphragm fixed. 4th pic shows other penny washer for connection of the back resistor. You can see the other penny washer for other back connection top right.5th pic shows it standing up on feet, although not quite finished. Final imp is 4.2 and 6.4 ohms for my ONKYO Amp. 6th pic another view on the dining table. Rebuilt these speakers from poor push pull design using 4.5 mm wide tape and 100 um polyester diaphragm material. A big improvement all round.
HENRY
Old 4th November 2012, 01:29 AM   #173
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
You don't happen to be related to Amar Bose?
File Type: png Screen Shot 2012-11-03 at 18.26.21 .png (116.5 KB, 196 views)
Old 4th November 2012, 09:54 AM   #174
No, why did you think so? Who is Amar Bose? I built that speaker 20 years ago!
HENRY
Old 4th November 2012, 11:55 PM   #175
He's got a lot more money than I have about a billion. He also designs more speakers than I have,although I prefer my designs to his.
HENRY
Old 7th November 2012, 09:59 PM   #176
steve1564 is offline steve1564
steve1564's Avatar
Henry - Bose only have 2 successful products & 1 of those is out of production!!! - from what i see here you have at least 15!!!
Wow what a great site!
Hi Everyone... & greetings from a damp north somerset
Been reading through the posts over the last few days - and have been considering building some planers for quite a few years now -
have a few questions / ideas:-
Magnets - the self adhesive type (plastiform) seem to have n&s poles running along the length - would there be an advantage to running a conductor between these as well as the gaps between the magnets?
And - could the field strength be increased by doubling up ? (one strip on top of another)
Foil - Aluminium or copper ? (for the above i guess you would need <2mm) copper, i guess would be easier to work with but is the extra mass a problem?
Diaphragm - Mylar seems to be the obvious choice - how tight ? i have an idea for a sandwich design that would tension the Mylar as the 2 half's of the frame was bolted together - you can then shrink another 2% with heat (same as the esl boys do)
- the Mylar would be tensioned before the "voice coil" is attached.
I had thought of using aluminised Mylar & etching the conductors on this - anyone tried this? (either diy or commercially ) - I've dismissed it on the fact that the aluminium is only a few atoms thick and would probably O/C as soon as you passed any real current through it
Sorry to wade in with so much on my first post - but this site has really got me wanting to get started !!
Steve
Old 8th November 2012, 10:23 AM   #177
steve1564's Avatar
New way to stretch diaphragm!....
Sorry couldn't resist it!!...
Old 8th November 2012, 08:47 PM   #178
Andersonix's Avatar
Steve: You are mixing up planar magnetics with electrostatics. If you want to go straight to the front of the queue, then skip past anything that invokes the black magic contained within magnets.
Old 27th June 2015, 05:21 PM   #179
Default my latest designs and my last I hope!
I have stopped using mylar and polyethylene use pics instead, much easier to build, and you don't have to tension the diaphragm neither!
HENRY
Old 27th June 2015, 05:37 PM   #180
Atom666 is offline Atom666  Canada
Atom666's Avatar
Hi James
Maybe I'm just being thick today but what is " use pics instead"?
Andrew
Planar speaker - first tryHide this!Advertise here!
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 399 7th November 2017 04:50 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 21 16th August 2015 10:28 AM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 09:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 04:38 PM
Copyright ©1999-2017 diyAudio
