Planars & Exotics ESL's, planars, and alternative technologies
New hybrid ESL Build
Old 28th August 2010, 12:18 PM   #21
Freddy G is offline Freddy G  Canada
Freddy G's Avatar
Hi mavric,
thanks for joining in!
I've been reading all I can about this stuff... actually, I read your entire thread a few nights ago, the 33 page one. I learned a lot, Charlie's blog is very informative too. I plan on thoroughly documenting my build with lots of photos as well.
Can anyone tell me about the diaphragm thickness? My previous post...
Old 28th August 2010, 12:56 PM   #22
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
3uM is a bit fragile, but can be used if the structure of the rest of the esl
is well built. Use 6 uM for good sound and long life.
Old 28th August 2010, 12:57 PM   #23
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Hi Freddy G.
I've tried both 6 and 3 micron Mylar. I prefer the 3 micron.
Wachara C.
Old 28th August 2010, 01:19 PM   #24
Freddy G's Avatar
OK thanks, that confirms what I thought... fragility issue.
chinsettawong,
can you describe the sonic difference between the 2? faster?
Old 28th August 2010, 01:20 PM   #25
CharlieM is offline CharlieM  United States
CharlieM's Avatar
Originally Posted by Freddy G View Post
What is the effect of the diaphragm's thickness? I see 6 micron film from TAC and also 3 micron on ebay. Is it simply a matter of thinner is better because of less mass up to a certain point where structural integrity gets compromised? In other words, if it's too thin then it could break too easily?
Maybe some one who's used the 3 micron film will chime in-- but since no one has, I will comment about 6 micron film.
As I said, I've only used the 6 micron film but your logic sounds about right to me. That is; at some point the mass of the film will limit the high frequency response-- the heavier the film, the lower the roll off point. Hence, 3 micron would be most accurate for highest frequencies. I don't know the roll off frequencies for the various weight films but I can attest that 6 micron is adequate beyond beyond what most of use can hear. I've heard that Martin Logan uses 12 micron film because it can be tensioned higher; so, how bad can 6 micron be, eh?
I know from working with 6 micron film that it's tricky to handle-- extremely strong in tension, yet it tears all too easily if you stress it along an edge. I use very sharp scissors to cut it off the roll so I get a smooth cut edge with no place for tears to start and then I handle it with the utmost caution. I suspect that the 3 micron film would be even tricker to handle and install but I doubt it would be prone to breaking once it's successfully attached to the stator.
I'm looking forward to hear the impressions of anyone who's used the 3 micron film-- so come on and chime in here, you guys!
Old 28th August 2010, 01:23 PM   #26
CharlieM's Avatar
Geeze! Three guys chimed in before I could get my last post in!
Old 28th August 2010, 01:38 PM   #27
I do not have any test measuring done. I only use my ears. I have tried 6, 3, 1.5 and 0.8 microns films with my headphones, and I like the 3 microns Mylar the best.
On my current ESL, I run them full range. I tension the 3 microns Mylar upto 1.5% elongation. My stretcher is exactly like what Charlie is using. I feel that I have all the bass I need without the need of using an extra subwoofer. As for mids and highs, I have nothing to complain about them.
Wachara C.
Old 28th August 2010, 01:45 PM   #28
CharlieM's Avatar
Old 28th August 2010, 02:23 PM   #29
JonasKarud's Avatar
The lesser treble in 6 or 12 my films is compensated for by the simple Peter Walker Law, which says: 5 mA ac in, 100 dB out. This applies for the perfect (theoretical) Esl of any shape or stator/stator distance. But we can use in practical Esl:s also, i.e with rising frequency in an Esl, the impedance lowers, the current increases and so does the output..this is why M-a-r-t-i-n L-o-g-a-n-s with 12um metalized membranes can play treble.
Old 28th August 2010, 06:13 PM   #30
MJ Dijkstra is offline MJ Dijkstra  Netherlands
I've worked with both 4 micron and 6 micron tensilized Mylar films.
While 6 micron is somewhat more robust, the 4 micron tensilized Mylar® turned out to be strong enough for all of my applications. In fact, using the very thin ones may prevent you from achieving a film which is stretched too tautly (too high resonance frequency).
Sonically, the 4 micron offers very smooth sound without sounding harsh. On the other side, 12 micron, sounded more like a (though good) dynamic tweeter. (12 micron feels like a thick cracking chips bag, 4 micron is more like a thin sandwhichbag)
drs M.J. Dijkstra
New hybrid ESL BuildHide this!Advertise here!
Final 0.3 Hybrid ESL TimA Planars & Exotics 36 7th November 2012 12:26 PM
Hybrid ESL, suitable x-over frequency? markusA Planars & Exotics 98 4th September 2010 09:27 AM
Geert - Hybrid ESL GeSo Planars & Exotics 21 24th September 2008 07:08 AM
Help needed with a diy hybrid esl badduh Planars & Exotics 29 10th January 2007 07:21 AM
ESL and Dipole hybrid system. christophorus Planars & Exotics 13 26th January 2004 09:18 AM
Copyright ©1999-2017 diyAudio
