Planars & Exotics ESL's, planars, and alternative technologies
Full-Range Dutch ESL Project File translated
Old 15th July 2010, 02:13 PM   #11
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by mavric View Post
Thanks for sharing, the pics are worth a thousand words. I would enjoy a project like that someday. What do you think the estimated cost for materials would be for say, 12 by 40"? And what kind of voltage for the step ups are required? As with everything on this site, I have never seen this before. A WHOLE lot different the panels I have. But thats freaking awesome.
Hello mavric,
Stator costs
Material cost for wire ESLs are not that much different from PSM(perforated sheet metal) ESLs. Certainly the PVC insulated wire is much cheaper than buying PSM and getting it coated. But, wire ESLs usually require some sort of jig to be built to hold the stator and wires while gluing everything together. For manufacturers that will use the jig to build many stators, the cost is quickly made up. But for DIY where you may only build one or two, it is a major part of the cost. For me, the results are well worth it. You get a very uniform, flat, well insulated stator this way. I attached a pic of my latest stators before I attached the diaphragm.
transformer costs
In general, wire ESLs require a transformer with 2 to 3 times the step up ratio as that used for most PSM ESLs. So, you can expect to pay 2 to 3 times as much. Ratios of 150:1 to 180:1 are typical. You need the higher step up ratio to keep the efficiency up with the segmented wire stators where your radiating width in the midrange may only be 2 to 3 inches. What you get for your trouble is much better dispersion of high frequencies. Most people find this to provide a much more natural and enjoyable listening experience. However, there are some people that prefer a very directional, beamy PSM panel.
size
For segmentated wire ESLs to work well and provide flat response down in to the bass range, the panel really needs to be taller than the 40" you mentioned.
Ideally, it would extend floor to ceiling. It doesn't take up any more floor space
Old 15th July 2010, 02:54 PM   #12
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Hi Bolsert,
Your stator looks really beautiful. Can you tell us more information on your build? How big will this ESL be? Is it possible that you share with us your stator wires tensioning technique?
Wachara C.
Old 15th July 2010, 11:46 PM   #13
mavric is offline mavric  United States
mavric's Avatar
Thank you for taking the time. I love the floor to ceiling, but mine is vaulted. I am trying to imagine your set, very interesting concept. the jig seems pretty strait forward, just distance between wire and distance between the mounts that secure it, hope that make since.
I tried to look closer at the picks you have posted and noticed different wire gauge, so is each partition on solid wire loop per partition, or are they cut and soldered, insulated at the top and bottom( per partition?)
Noticed test tones, i will no longer do that anymore. it is really bad for any audio setup.
Look forward for more info and pics, since I have joined, I have only had a few things posted from you, all were great and very informative, much appreciation. Kind regards. Mav
i do have a loft, building a 15 foot jig sounds like fun. You and Charlie have me addicted to this, almost better than sweet tea. keep posting, you are waking up everyone.
The only true wisdom is in knowing you know nothing.
A wise man does not need advice and a fool won't take it.
Old 16th July 2010, 12:20 AM   #14
slr 5000 is offline slr 5000  Australia
hi all
i also have to say that your stators are very professional looking !
im glad this thread has started as i have found that although there is a fair bit about building wire stator esl on this site it is scattered and hard to put together
im hoping this thread will become a solid resource for this type of esl .
i am currently building a set of wire stators and am looking for any and all info i can get , i did try to adapt my er audio acorn panels to start but they are not really suitable
i am as we speak getting some new plastic pvc stators cut and routed that are inspired by the capacity esl with some tricks i have learnt from looking at the er acorn stators and building method
i look forward to getting started and learning all i can from this site to make my build succesful
cheers sheafetr
Old 16th July 2010, 01:27 AM   #15
bolserst's Avatar
Originally Posted by chinsettawong View Post
Hi Bolsert,
Originally Posted by slr 5000 View Post
hi all
Hello and thanks for your kind comments. It is a blessing and a curse that forum postings wander off in all different directions, scattering the information. But, at the same time, you might stumble on something you never would have otherwise.
I had posted my general technique for building wire stators here in the wire stator design thread:
http://www.diyaudio.com/forums/plana...ml#post1906849
Basically, wire is wound back and forth between pins in two end blocks. One end block is fixed, the other moveable. Once all wires are wound they are all stretched at once, enough to straighten and strengthen(cold work) the wires. Then I release most of the tension before gluing wires to crossbars. I stretch my wires about 1%-2%. I got the idea from the Janszen patent where he mentions stretching his wires 6% before assembly.
USpatent 2896025 (column 4, line 40)
http://www.google.com/patents/about?...BAJ&dq=2896025
Old 16th July 2010, 01:41 AM   #16
bolserst's Avatar
Hi maveric,
The wire I used in the stators is all of the same gauge. It is 22 AWG solid wire with 1/64" PVC insulation rated at 1000V. Wire was spaced 9 wires to the inch resulting in an open area of 47%. The panel will be split into a center section, and 6 pair of outer sections. The sectioning is easily done by cutting the end loops of the wire at the appropriate location and soldering in the feed resistors. Refer to the picture of the Capaciti resistor network in post #10 of this thread.
Yeah...about that 15 foot jig
I'd recommend making a 5 foot jig and build 3 sections; much easier to deal with.
Old 16th July 2010, 02:30 AM   #17
Hi Bolsert,
Are you serious about 15 foot jig. Wow! That makes huge ESLs.
Wachara C.
Old 16th July 2010, 02:43 AM   #18
alexberg is offline alexberg
alexberg's Avatar
Originally Posted by bear View Post
alexberg,
not sure what you are saying - but you need VOLTAGE to drive an ESL, so the amp "power" is mostly related back to the voltage needed to drive the primary of the stepup transformers that drive the stators, so that enough voltage is produced. Yes, there is some current too, but it's mostly the voltage required.
So you can make direct drive amps, or use OTLs with most ESLs as a result.
This may be what you are interested in... not sure...
_-_-bear
Speaker looks very nice. Great workmanship
Back to the question... Why do low power/low voltage resistors used?
Am I missing something?
Assuming panel capacitance is 1500pF (spacing 2mmx2=4mm)
Only half is drawn
5kHz
UR1=1400V UR2=290V UR3=50V
PR1=5.5W PR3=0.12W PR5=0.0W
2kHz
UR1=1250V UR2=600V UR3=105V
PR1=4W PR3=0.5W PR5=0.01W
Having impedance of 4 Ohms @ 100W one needs not some current but at least 5A @ 20V or 33 mA @ 3000V
Alex
P.S. Try to burden resistor (MF or Carbon Comp) with two times rated power...
Old 16th July 2010, 03:49 AM   #19
bolserst's Avatar
Hi Bolsert,
Well, I was serious that if maveric was considering building 15ft ESLs he should do it in smaller sections.
The stators I pictured are for ESLs 6.5 ft tall.
Old 16th July 2010, 07:21 AM   #20
mavric's Avatar
I will get started this weekend and post pics as I go.
>22 awg solid copper is the same wire used in homes, romex. however 22 will be hard to find but I have a source i can get 500' for around 30usd.
> good idea going in three sections, i would think a dowel rod or two to mate and remove the jig will work.
> as far as the components go, i have a pretty good understanding, as long as the load stays at or around 3 ohm. that is if I have read the link correct.
By the way, good job, everyone is awake now. Later, MAv
just to make 100%, the wire is pvc, poly vynal chloride isulated, solid copper wire. Much appreciation. Now I have to talk Charlie into building a set, he, he.
Full-Range Dutch ESL Project File translatedHide this!Advertise here!
Building / Designing my first full range esl electros Planars & Exotics 1 2nd June 2010 03:06 PM
.slb file (translated library file)...! spice freak Solid State 0 28th October 2008 03:20 PM
Full range ESL vs ESL + sub Jacobus Planars & Exotics 18 24th September 2007 02:50 AM
Dutch ESL builders attention...part ESL for free Bas Horneman Swap Meet 10 14th June 2005 07:54 AM
Help in designing a full range ESL transformer PLEASE! mwmkravchenko Parts 11 8th June 2005 12:27 PM
Copyright ©1999-2017 diyAudio
