Planars & Exotics ESL's, planars, and alternative technologies
Martin Logan SL3 = dead => help
Old 5th October 2010, 10:01 PM   #11
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Originally Posted by peranders View Post
I'll let you know how it went.
Update, P-A?
Old 6th October 2010, 04:14 AM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Still broken but some day very soon I plan to fix this.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 7th October 2010, 04:11 AM   #13
nac134 is offline nac134  Canada
I have had a similar problem. It was arcing, but it was happening in the wiring, and not on the actual panel. This will be hapening either between the power supply board and the panels or the transformer and the panels. Keep in mind that very lethal voltages are involved, so be careful. Either buy some rubber gloves, or be sure to keep one hand in your pocket at all times - is when the voltage travels from one hand to the other, ie across you chest, that you can get really hurt.
Old 14th October 2010, 11:27 AM   #14
JonasKarud is offline JonasKarud  Sweden
JonasKarud's Avatar
Per-anders, you must, in the future, consider that the folks on DiyAudio lays down a quite an amount of thinking to solve YOUR problem, and that it's interesting for us to know whether the problem is solved!!
Reality is just a word....
Old 14th October 2010, 06:23 PM   #15
peranders's Avatar
I will notify you when I have fixed the speaker. It's still out of order.
Old 14th October 2010, 07:35 PM   #16
peranders's Avatar
Have you any personal experience of this, I mean the electrical chock?
Old 14th October 2010, 08:52 PM   #17
enilsen is offline enilsen  Sweden
I have had a similar problem with ML speakers and it was due to the strip of aluminum foil along the bottom of the membrane loosing contact with the conductive coating. This is where the static charge is transferred to the membrane.
To test if the static charge is not reaching the membrane you can borrow a static charge from the other panel by using a test wire with a flat metal tip. Be careful not to discharge against the stators. You do this while music is being played through the speakers.
Old 14th October 2010, 09:13 PM   #18
I have actually zapped myself on my electrostats with more than 2000 volts, but only across my hand, never across my chest. Roger sanders, the designer from innersound and the inventor of the curved electrostatic panel told me that a shock from the power supply across the chest could stop your heart (he was helping me when I had an arcing problem). Besides designing speakers, he's also a medical doctor, so I took his advice.
In my case the arcing was happening very close to where the signal wires enter the panel.
Old 15th October 2010, 05:30 AM   #19
Franz Gysi is offline Franz Gysi  Switzerland
Franz Gysi's Avatar
THIS is dangerous, because the signal voltage is at high level and can deliver much more current than the polarizing voltage!!!
Potentially lethal.
Franz
Old 15th October 2010, 05:58 AM   #20
Steve M is offline Steve M  Australia
Sorry to say, but this is really BAD ADVICE! DANGER!! DANGER!! ELECTROCUTION HAZARD!!
The maker of my stat told me quite emphatically do NOT go poking around when the stators are charged and especially when music is playing as there will be up to 6000v there to zap you!
Martin Logan SL3 = dead => helpHide this!Advertise here!
Need help with Martin Logan speaker JariV Multi-Way 10 18th November 2008 06:04 PM
Martin Logan SL3 Woofers? jbeckley42 Planars & Exotics 7 24th October 2007 02:58 PM
martin logan csl flodge Planars & Exotics 12 13th November 2005 02:59 PM
Martin logan ascent jouch Planars & Exotics 0 25th March 2004 07:02 AM
X-Aleph and Martin-Logan Faber Pass Labs 2 7th November 2002 08:40 PM
Copyright ©1999-2017 diyAudio
