Acoustat spectra 33 x-over Acoustat spectra 33 x-over - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 16th May 2010, 02:22 PM   #1
magig160 is offline magig160  Canada
Cool Acoustat spectra 33 x-over
Hi guys,
First Hi to everyone, it's my first thread,
Ok I a have a question for you guys, I recently swat a pair of model 3 red medallion into spectra 33. The speaker are done and work perfectly, but I have something in my mine that bother me. Maybe one of you can help me with that.
In my version I didn't use any subwoofer as the original one, so I didn't install the swith and the 10ohm. Someone who knows very very well the acoustat told me that I need the keep a minimum of 47uf where the input signal is.
My question : why I need to keep a minimum of 47uF, why I can't remove all the capacitor, I don't need any x-over it's a full range speaker...? If someone can take 5 min of their time for me I'll really appreciate
thank you very much,
Sorry for my english!
Matt
Old 16th May 2010, 03:02 PM   #2
bolserst is offline bolserst  United States
bolserst's Avatar
According to the circuit diagram you posted when the switch is put in full range position the 10 ohm resistor is removed and a 1 ohm resistor is put in parallel with the input capacitors. Do you have this 1 ohm resistor in your circuit?
For full range operation the 1 ohm resistor effectively bypasses the capacitors at low frequencies providing full signal strength in the bass. It also helps keep the transformers from saturating on large bass transients. At high frequencies, the capacitors in parallel with the 1 ohm resistor will bypass the resistor allowing full treble response. Perhaps this is what your friend was saying about keeping a minimum of 47uF in the circuit.
Moray James knows Acoustats very well. Hopefully he will be able to give you a better answer.
Old 16th May 2010, 11:22 PM   #3
Thank you very much for the fast answer Bolserst, I'll certainaly talk with Moray, Is he here in that forum ?
Acoustat spectra 33 x-overHide this!Advertise here!
Amp suggestions for Acoustat Spectra 22's? JmanGTA Planars & Exotics 11 1st May 2012 10:41 AM
Acoustat 1+1 from Spectra 1100? noelm Planars & Exotics 2 19th February 2007 05:52 PM
Acoustat Spectra Delay Line - Any Experts? Magnetar Planars & Exotics 6 7th February 2006 07:25 PM
33,000u/60V and 33,000u/75V Peter Daniel Swap Meet 2 7th March 2003 12:36 PM
Help for Acoustat Spectra 33 Oz_Audio Multi-Way 7 18th October 2002 08:01 PM
Copyright ©1999-2017 diyAudio
