Planars & Exotics ESL's, planars, and alternative technologies
Why Stax headphone being so small can go down to 6Hz?
Old 1st May 2010, 06:47 PM   #1
zhoufang is offline zhoufang  Singapore
Default Why Stax headphone being so small can go down to 6Hz?
If I did not get it wrong most Stax headphones are of ESL nature.
From what I read ESL cannot go low enough for full range unless it is a few meter in diameter?
So how does Stax, being 10cm or less in size, can go 6 to 41,000 Hz?
Open air type Earspeaker : SR-007MK2 (OMEGAII)---New products
I did some search but did not find any result.
There must be something obvious that I missed out.
Old 1st May 2010, 08:17 PM   #2
geraldfryjr is offline geraldfryjr  United States
An esl of any type will go as low as you want it too, as with any speaker.
It all depends on what type of method is used to drive them.
If a if a transformer is used to drive them it would take a rather large core and high primary inductance to achieve a good response below 10 or 20 hz but it can be done as I have done this ,but at a very low level.
The stax system uses a direct drive system ,and, that low of a response is easily achievable because there is no transformer to limit the low frequency response of the amplifier.
I hope that helps you to understand. jer
Old 1st May 2010, 09:45 PM   #3
Dear Geraldryjr,
Your explanation definitely enlightened me, thank you!
I know I missed something.
But I do still have some questions.
Tube amps use output transformers too, although in step down rather than step up as used in ESL amp.
And some ESL amp are using old tube amp's output transformer in the opposite direction.
So why did output transformer in ESL amp attenuate the bass, but not in tube amp?
I am also under the impression that ESL speaker with larger membrane do better into the low frequency.
If transformer is the limit, how does larger membrane help?
It is that, because larger membrane need smaller movement to create the same SPL, it needs lesser voltage and higher current to drive to the same SPL, thus allow for lower transformer ratio, which cause less attenuation in the bass?
If the above guess is right (lower transformer ratio means less attenuation in the bass), then every ESL builder should be looking for high native voltage amps (which need less step up ratio), I'm not sure if this is the case.
A lot of questions. Would appreciate any answer.
Old 2nd May 2010, 06:35 AM   #4
"Tube amps use output transformers too, although in step down rather than step up as used in ESL amp.
So why did output transformer in ESL amp attenuate the bass, but not in tube amp?"
A little more info as to which amps and transformers are being compared.
Most tube amp OPT's are only designed for a maximum lowest of 40hz to 80hz or so at -3db so the flat resposne is higher than that by at least an octave for an average to mediocre hi-fi tube amp and is the norm for guitar amps.
For for higher quality OPT that goes down to at least 20hz flat requires at 4 times or more iron than a power transformer with the same power rating at 60hz.
This is the reason that a that a 50 watt high quality transformer that goes to 20hz or better are so expensive and large.
For instance if you take a look at some of the plitron transformer spec's such as a 70 watt opt that goes to 20hz you would see that by the size of it, one would think it should handle at least 300 watts of power or more.
In which it could but not at 20hz.
"I am also under the impression that ESL speaker with larger membrane do better into the low frequency.
It is that, because larger membrane need smaller movement to create the same SPL."
Yes this true,but ther are two factors to take in consideration here.
First it takes (x) amount of displacment to produce (y) amount of spl at (z) frequency.
So in order to produce alot of bass (or more spl at any frequency for that matter) one must be able to displace a large amount of volume of air and is linear as per octave.
Something like 2*(x) for (z)/2=(y)spl
(some one can jump in and correct me if I am wrong but I am pretty sure it is right)
So increasing the surface area is the best way to combat the problem of a limited excursion of an esl.
I have found that a suface area 4 to 6 times that of a single dynamic driver, is equivalent to the single driver(due to the limited excursion)as a good giudeline.
Second, due to the the nature of a dipole radiator the lower frequency's get cancled by the backwave and there are several ways to combat this.
Increasing the panel width and/or adding wings on the sides to effectively increase the width and by bass boost filtering or both.
If you were to mount the panel in a wall (with the back side open of course) eliminating the back wave cancellation you would find plenty of bass and spl's only limited by the surface area and maximum excursion just like any other speaker.
This was meant for as an example,and there have been many discussions about this type of mounting and I don't wish to open that can of worms at the moment.
"It is that, because larger membrane need smaller movement to create the same SPL, it needs lesser voltage and higher current to drive to the same SPL, thus allow for lower transformer ratio, which cause less attenuation in the bass?
If the above guess is right (lower transformer ratio means less attenuation in the bass), then every ESL builder should be looking for high native voltage amps (which need less step up ratio), I'm not sure if this is the case."
The transformation ratio does not determine the low frequency response of a transformer.
The primary inductance does.
From this (primary turns) the transformation ratio determines how much of a load the panel presents to the amplifier.
Yes it is logical to say that high voltage swing from the amp and lesser turns ratio is the way to go,but in fact the opposit is true.
As stated in another thread and in my transformer testing has shown that in order to keep the core form saturating at a higher voltage at (x)frequency then one must use more primary turns and this is directly refelcted to the amount of secondary turns needed to keep the same ratio which greatly increases the secondary winding capacitance,not good.
But, yes, the trade off is the higher the voltage swing the lesser transformation ratio can be used.
The other trade off is raising the lowest usable frequency,but then we wouldn't have a fullrange system anymore,would we?
This is a subject where compromise plays a big part and I have found that in order to get around these issues is to use a very large core and I have recently found a vendor where I can get such larger cores rather cheaply.
starting with a 1800va torroidal at about $20 to $30.
Using a large core will allow me a nice low frequency and still be able to use a high transformation ratio as it will require less turns on the primary by as much as a factor of 4 times or more compared to the 200va core I am using at the moment greatly reducing any added secondary capacitance.
I think I have covered your most of your questions.
If not,keep asking . jer
Old 2nd May 2010, 07:01 AM   #5
gaetan8888 is offline gaetan8888  Canada
Hello
Can you tell me the vendor name ?
Thank you
Bye
Gaetan
Old 2nd May 2010, 07:12 AM   #6
Yes,the vendor is alphacoredirect.com . jer
Old 2nd May 2010, 08:32 AM   #7
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
All that I know.
That is not strictly correct. ESL's can produce very low frequencies without problem. However as they are dipoles these low frequencyies will be partially cancelled by the dipole action. This of course can be equalised.
However as ESL Diaphragms cannot move much it is not really possible to apply much equalisation, unless the diphragm is made very large.
First, headphones differ greatly from any speakers. If you have open backed headphones (such as the Stax), you have a situation where the headphones cushion closes the system against your ear, so in effect you are sitting inside the Box with the other side of the headphone venting in the room! Under those conditions the LF response can be quite extended on the "inside".
If you listen to the sound emanating from headphones sitting on spomeone elses head the sound is typically tinny with no bass. This changes dramatically when the headphones are on your ears.
Secondly, based on measured performance (Boston Audio Society - November 2002 Meeting Headphone Test Clinic) the Stax ESL headphones are at least 10dB down at 20Hz, one may speculate that at 6 Hz they would be at least 20dB down.
Stax specify neither the actual measurement methode nor the limits for this frequency response, so the number is meaningless.
I have a pair of small active PC speakers that rolls off below 100Hz at 12dB/Octave and barely reaches 10KHz with any flatness.
If I wanted to though, I could claim it performs 25Hz - 40KHz.
I would only need to perform my measurements with a -24dB flatness and omit stating this anywhere (or at best state it in the most well hidden small print).
Yes. You first missed that the numbers are pure marketing specmanship (see the measurement in above link) and secondly you are missing the fundamental differences between how headphones and speakers operate.
As for all that talk about transformers, pulllleeeessse!
Gerald, you are so far off, it is severely unfunny. The transformers in ESL's are not the limiting factor. At any extent, they can be removed (a friend is running a 3-Way system that uses "DIRECT DRIVE" ESL Panels for high frequencies and upper bass/midrange. The LF limitations of the Midrange Panel are not down to the transformer, it ain't using one.
But because of the limited size it rolls off at around 150Hz and is equalised only down to around 60Hz to avoid overdriving the panel (which produces arcing and burns holes into the film).
Ciao T
Old 2nd May 2010, 09:14 AM   #8
"Gerald, you are so far off, it is severely unfunny. The transformers in ESL's are not the limiting factor. At any extent, they can be removed (a friend is running a 3-Way system that uses "DIRECT DRIVE" ESL Panels for high frequencies and upper bass/midrange. The LF limitations of the Midrange Panel are not down to the transformer, it ain't using one. "
If a transformer isn't a limiting factor then why is your friend not using them instead of a direct drive system?
I personaly would rather use a direct drive system and will have working in the near future.
I simply stated as to why an average opt does not have a very good low frequency response.
I did not state that the transformer is the only limiting factor
"Second, due to the the nature of a dipole radiator the lower frequency's get cancled by the backwave and there are several ways to combat this.
Increasing the panel width and/or adding wings on the sides to effectively increase the width and by bass boost filtering or both."
"So in order to produce alot of bass (or more spl at any frequency for that matter) one must be able to displace a large amount of volume of air and is linear as per octave"
"A little more info as to which amps and transformers are being compared."
Obviously you missed the quotes and too what was quoted and what I stated to what was quoted. jer
Old 2nd May 2010, 09:27 AM   #9
Because we are already using tube Amp's that swing enough voltage and direct coupling saves the cost, weight, size of two transformers?
However, my point stands, the Transformers are not the reason LF output from ESL's is limited and direct-drive cannot help to extend LF response, as the point where the limitations of a competently designed transformer are happens far below the cutoff enforced by dipole action and limited excursion of ESL panels.
Sure, but it will not get you an iota of LF extension, unless your transformers where very badly designed. I'm very much in favour of direct drive to ESL's, as mentioned, I worked with my Friend on his system and designed the Amplifiers.
Funny. I routinely work with tube amplifiers where the frequency response is essentially flat to 20Hz and with -3dB points in the 10Hz region or so (mind you, not at full power, but few amplifiers are running near full power with music).
So, again, in practice the transformers do not HAVE TO BE a limiting factor.
Ciao T
Old 2nd May 2010, 09:35 AM   #10
spritzer is offline spritzer  Iceland
spritzer's Avatar
Those numbers are all but meaningless but a well driven Stax SR-007mk1 (not the Mk2 since the baffle isn't sealed) will go very low. Stax aren't alone in giving out such meaningless measurements as when Sennheiser manufactured electrostatics (HE60 and HE90 aka The Orpheus) they claimed for the 12Hz-65kHz former and 7Hz-100kHz for the latter but at -10dB. Beyer did it too with the only electrostatic they made, the ET1000 (10-25000hZ).
Thanks for that, something regarding Stax headphones that I hadn't seen before. Not sure what driver they used for the Stax headphones but if it was the SRM-T1 they keep talking about then no wonder they ran into issues. That amp uses 6CG7 tubes which are pushed way past their limits and the simple CRC PSU is far from ideal. Still not nearly as bad as the Koss E/90 amp, the ESP950 would have fared a lot better off the SRM-T1. I doubt they could have found a Stax SRM-T2 for the comparison but that would have made it truly interesting.
Why Stax headphone being so small can go down to 6Hz?Hide this!Advertise here!
Stax headphone questions amt Headphone Systems 4 9th March 2014 06:09 PM
stax headphone extension cord mmerig Headphone Systems 3 30th July 2011 04:06 AM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 09:24 PM
Stax headphone sockets? Wavebourn Swap Meet 6 8th January 2009 06:43 AM
Needed: Small efficient headphone amp(no SQ requirement) theAnonymous1 Headphone Systems 8 6th December 2006 10:45 PM
Copyright ©1999-2017 diyAudio
