Planars & Exotics ESL's, planars, and alternative technologies
My own take on Air Motion Transformer
Old 7th March 2010, 03:39 AM   #1
NV&H is offline NV&H  United States
Default My own take on Air Motion Transformer
OK, here's what I'm working on. See image. 32awg aluminum wire coil. Very thin mylar backing and, as you can see, a "surround" made of very thin packing foam sheet. This thing will be slid into a 2"x1"x2" >1T gap with the "surround" glued to the magnet surfaces on each side. The non-corrugated section will simply be folded out of the way. Because of the direction of current flow in the gap, the magnetic flux lines are 90 degrees out from what I see in Heil's and most other designs. This gets rid of the "storm drain" looking structure in front of the ribbon you see in other designs. I hope to get sound in the next few days. Should be able to run it full range. The magnetic assembly has already been built. Just takes time for the "surround" glue to dry.
NV&H
Old 8th March 2010, 03:51 AM   #2
srinath is offline srinath  United States
I dunno which way your wirs are running relatove to the pleats ... but the heil and I recently dissected one, has magnetic lines of force going away from you, wiring running up and down in front of you - current running up 1 wire, down the other etc with each wire on adjacent sides of a pleat ... and when you run current through it, they come closer in 1 pleat, and go further apart in the adjacent pleat, like an accordion.
Sound is compressions and rarefactions in air, and it directly makes those in the air.
Cool.
Srinath.
Old 8th March 2010, 06:11 AM   #3
godfrey is offline godfrey  South Africa
I'm interested to see the magnet structure. Must be a monster!
Old 10th March 2010, 06:36 PM   #4
Cool.
Srinath.
The current runs 90 degrees out from what the Heils do, so that's why I had to arrange things such that the magnetic flux lines are also 90 degrees out from what the Heils do. It wound up working nicely but then some toe-nail clippers got to near the gap and got sucked in. Destroyed the ribbon. Oh well, back to the drawing board.
Yeah, the magnetic structure is comprised of eight 2"x2"x1" magnets. The way I have them arranged, it's rather compact. The whole assembly is 5"x5"x2" with a slot opening where the flux is concentrated that is 2"x2"x1".
NV&H
Old 11th March 2010, 04:08 AM   #5
If the wires run side to side, but magnetic lines of flux go away from you then the wires will get pushed up and down. That can make its own heil like sound. Anyway put pics up. I have a destroyed diaphragm too from what could have been a screwdriver.
Cool.
Srinath.
My own take on Air Motion TransformerHide this!Advertise here!
Beyma TPL-150 air motion transformer StigErik Planars & Exotics 5 12th July 2009 11:05 AM
DIY Air Motion Transformer idea woody Planars & Exotics 2 23rd March 2008 01:58 PM
DIY Air Motion Transformer OliverD Multi-Way 55 10th April 2005 12:28 AM
Copyright ©1999-2017 diyAudio
