different ideas for ESL panels different ideas for ESL panels - Page 4 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 2nd March 2010, 03:34 AM   #31
geraldfryjr is offline geraldfryjr  United States
call me when you can .i hope it isn't any thing serious and you are okay .yur bud,jer
Old 2nd March 2010, 01:11 PM   #32
mavric is offline mavric  United States
mavric's Avatar
thanks Ger, sorry to get off subject, some things happen so i figured i would provide an explanation. it is a famaliy matter, no one is hurt, but my projecct is on hold for a little while. Ger, if you can, kindly give me a call, 7:00 est. time, you should have a pic of the Adcom preamp on your computer, i sent it @ 12 or 16 megs, remember the screw driver i used as refffence, the "tone in" switch was fauted and i lost the paper work for bypassing a double pole relay on the board, thats why its not on the forum. here is a reminder photo of cutting the traces, cannot remember the 4 jumpers and pins that you suggested. i know it looks buggered up, just havent cleaned around it yet. if you need another high res, check your email. very large file.
my brother, Jason was in a bad accident, so thats where my head ache was posted. just to clarify for "Jason" moderator.
gotta go to the hospital. wish him luck!
Charlie, i am sorry i could not make it Sunday, this is what came up, family takes first as thats my only brother.
this is completly off subject, I just wanted my friends to know here @DIY. Mav...
The only true wisdom is in knowing you know nothing.
A wise man does not need advice and a fool won't take it.
Old 2nd March 2010, 01:50 PM   #33
understood mav, i call you this evening.good luck. jer
Old 4th March 2010, 03:38 AM   #34
mavric's Avatar
Trying to get things situated here, sorry for the personal drama, i guess it come with being married with a son and spending all the time your not working, on the computer or just not spending time. So let that be a message, put your family first.
I'm back, and look forward to moving on the build. Charlie, might try this again this weekend if thats ok with you. I still have to coat the panels, i guess i will degrease them with my pressure washer and some solution.
Ger, can you please check your email at home that hss a res pic of that board again. Thanks Mav
Old 4th March 2010, 11:08 PM   #35
mavric's Avatar
Charlie was kind and drew up a drawing of my stat supports, will try and post deminsions and measurements as well.
I am still playing with the idea of rhino lining, however, we also have primer that we use to coat "bare" metal, rhino likes to stick to a slightly scuffed painted surface, since these are bare metal, the primer is a two part mixture, all they put on the bottles is part numbers, it is probally propritary mixture. I will take some pics of it and see if anyone recognizes it. That way i can maintain a perfect 10 mill apllication with out worries of cloogging the panels and keeping my open area, a little more open. I like it as it is clear, and will better showcase the stats.
Old 4th March 2010, 11:32 PM   #36
mavric's Avatar
a pic of my sub enclosure in the works, need more wood..
Old 4th March 2010, 11:50 PM   #37
hi mav, here is that diagram, i also inclueded the acutal symbols to help you understand the circuit.jer
Old 5th March 2010, 01:14 AM   #38
mavric's Avatar
just so i have this right
<combine > combine
. cut .
<combine >combine
. cut .
is this correct?, thereis something else i noticed on the board, here is a pic, if you need his res, let me know, Mav
here are the pics
Old 5th March 2010, 03:39 AM   #39
mavric's Avatar
thanks Ger, have the info you provided. works well.ish others would be so kind. I am open to ideas and new info. Mavric
Old 6th March 2010, 11:37 PM   #40
mavric's Avatar
Going to Savannah Sunday, gonna try and finish cutting for the TL's and stats. I will post more detailed pics as well as the remedy for my preamp care of Ger( thanks).
I will very soon have a posting on YouTube with video, most of it will be common for builders, but maybe insightful for new comers into this field.
different ideas for ESL panelsHide this!Advertise here!
2 Small Panels or 1 Large One - ESL audio.ESL Planars & Exotics 24 3rd November 2009 08:18 AM
Loudness etc. of ESL panels jjbunn Planars & Exotics 10 13th November 2008 11:52 AM
JanZen ESL panels cowanrg Planars & Exotics 6 17th December 2007 05:01 PM
Repairing ESL Panels / Corona problem volkerw Planars & Exotics 9 21st June 2007 06:56 AM
Wraith ESL panels Sheriff Planars & Exotics 0 14th August 2004 05:37 PM
Copyright ©1999-2017 diyAudio
