Planars & Exotics ESL's, planars, and alternative technologies
Step-up transformer design
Old 11th March 2013, 02:22 AM   #271
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by alexberg View Post
Shield has nothing to do with the "leakage" inductance which is due to coupling between the windings. Shield are to reduce stray (electro)magnetic field emanated by inductor/x_former/etc.
A shields affect on leakage inductance would be indirect.
Its presence does not directly affect leakage inductance but it may affect the distance between the primary and secondary which will change the leakage inductance.
Old 11th April 2013, 07:33 AM   #272
Legis is offline Legis  Finland
Legis's Avatar
Originally Posted by Legis View Post
The transformers' specifications that I ordered:
- Core's area ~11,5cm2, core material grain oriented silicon steel, Bmin = 1.7T
- 2 x 30 turn bifilar wound primaries (2,0mm2 wire)
- 2 x 120 turn bifilar wound secondaries (0,44mm2 wire)
- Primay is wound close to the core, secondary on top.
- Electromagnetic shield on the outer rim
I finally received the 1:8 step-up transformers. Primary leakage inductance (primaries in parallel, secondaries shorted) appears to be ~1-1.2ÁH @ 650khz and the secondary parasitic winding capacitance 570pF (secondaries in series) @ 550kHz. (I cannot change the measurement frequecies.) After I have build the interface boxes I will do some measurements w/wo the trafo's in the signal path. For me it's very intersting to see and hear how the step-up trafo changes the sound and measurements of a dynamic driver, haven't tried this before.
Step-up transformer designHide this!Advertise here!
Step Down Transformer Ropie Power Supplies 3 15th October 2006 09:42 AM
Can I use a step-up transformer as step-up? cviller Parts 5 6th September 2006 06:32 PM
help design SE preamp with mosfet buffer and step-up transformer. AudioGeek Solid State 0 19th January 2005 03:02 AM
Help Newbie Design X-over Step-by-Step Kongen Multi-Way 3 21st November 2004 02:32 AM
Using one transformer to step down another. Shoog Solid State 9 28th August 2003 10:00 PM
Copyright ©1999-2017 diyAudio
