I Was Wrong I Was Wrong - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
I Was Wrong
I Was Wrong
Old 15th November 2009, 04:10 AM   #1
Borat is offline Borat  United States
Banned
Default I Was Wrong
i had a feeling this was the case from the beginning but somehow i manged to fight that feeling off then. but i have come to grips with it now.
i am talking about :
http://www.diyaudio.com/forums/plana...1474-plur.html
http://www.diyaudio.com/forums/plana...sodynamic.html
http://http://www.diyaudio.com/forum...evolution.html
i previously implied that this technology allows one to create wider ribbons - almost as wide as planar speakers or ESLs.
that was WRONG.
in fact it doesn't provide any advantage in possible width over regular ribbon technology.
this is to say field strength still drops proportionally to 1/gap width. my apologies to everybody.
this fact was somewhat obscured by peculiarities of the design as it doesn't manifest itself "at first". instead it acts more like an asymptotical limit. but this limit is there and there is no way around it.
however this can be viewed also as a blessing in disguise. because while on one hand it means ribbons wider than about 2" are impractical on the other hand it means that the technology allows for much higher field strength with conventional width ribbons than my original 4" wide model had.
the linearity benefit is real though. and "plur 2" takes it to its ultimate conclusion.
i will next post some simulations of a standard 1" width ribbon motor.
Old 15th November 2009, 04:18 AM   #2
Banned
i narrowed the gap from 4" to 1" to recover field strength.
the maximum peak to peak excursion ( space between front and rear magnets ) here would be 0.5"
I Was Wrong-p2n-jpg
i made a plot of the field along this red line:
I Was Wrong-horizontal-line-gif
which looks like this:
I Was Wrong-horizontal-plot-jpg
and along this red line:
I Was Wrong-vertical-line-gif
I Was Wrong-vertical-plot-jpg
so in fact the technology allows for the same kind field strength levels as you would expect to have in a conventional ribbon but with absolute linearity.
as for the argument that magnets in front of the ribbon would interfere with sound - the AMT drivers such as Beyma have sizeable obstructions in front of the "ribbon" and nobody complains.
Old 17th November 2009, 07:19 PM   #3
gymwear5 is offline gymwear5  United States
With the gold ribbon concept loudspeaker and other push-pull ribbon designs the acoustic cavity in front and behind the driver create a tuned chamber that creats a Hump in the respnse - with the GRC the hump was at 7Khz - but was broad enough to be EQ'd out by the crossover.
Old 18th November 2009, 08:36 AM   #4
Banned
i tried searching for "gold ribbon concepts 3.0" but couldn't find a single picture.
if you don't have a picture could you perhaps draw a sketch of what it was like ?
I Was WrongHide this!Advertise here!
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
BIB's, what did I do wrong? Rick J. B. Full Range 23 17th March 2008 10:46 PM
Where did I go wrong? Cup of coffee Solid State 31 26th June 2007 04:26 AM
First GC Amp .... something wrong? sl_1800 Chip Amps 29 29th December 2004 03:32 PM
What am I doing wrong???? Chuck Richey Everything Else 14 17th July 2003 08:42 AM
Copyright ©1999-2017 diyAudio
