Planars & Exotics ESL's, planars, and alternative technologies
Astonishing discovery
Old 10th February 2010, 03:57 AM   #41
rok-n-rol is offline rok-n-rol  United States
rok-n-rol's Avatar
Originally Posted by cpcc View Post
That looks like an old wrinkled piece of gray Duct tape to me. On the topic of just making sh-t up I know I should Probably should start a new thread but...
You get a similar effect by mounting 3/4 inch domes in the tips of a wonder bra.
You can also mount mid domes the same way using different cup sizes to tune the rear cavity.
Any other ideas using these techniques?
Do you have any photos of your tittilating design?
Old 10th February 2010, 02:57 PM   #42
jackinnj is offline jackinnj  United States
jackinnj's Avatar
I think that there's a picture of Beyonce on the web using gray duct tape to prevent a wardrobe malfunction, or to keep something from popping through...
Old 10th February 2010, 11:36 PM   #43
keantoken is offline keantoken  United States
keantoken's Avatar
Could this same technique be applied to ribbon microphones?
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 5th April 2010, 06:26 PM   #44
artm is offline artm  United States
Any update on this thread?
Old 19th May 2010, 08:45 PM   #45
NV&H is offline NV&H  United States
As it turns out, the hose detached from my ribbon eventually. As I mentioned previously, the hose was glued to the ribbon when it was stretched out. When the 3M glue dried, I detentioned the hose and trimmed away the excess. Over time, the glue failed to keep the tensioned hose in place on the ribbon's surface. So now, I'm doing the same thing except I'm not detensioning. I've stretched the hose on a frame and glued the ribbon on in the same way and left the assembly in tensioned. That way the glue doesn't have to carry load of the tensioned hose.
NV&H
Old 19th May 2010, 09:28 PM   #46
geraldfryjr is offline geraldfryjr  United States
Good update, as I was wondering how long the 3M glue was going to hold up under tension bonded to nylon.
How long (time wise) did it take for the glue to give up.
Maybe there was to much tension with the hose for the glue to handle.
Can you get the same effect using a woven fabric such as silkscreen material with a little tension when applied the same way?
Although it might not be as springy?
Forgive me as it has been awhile and I don't remember all of the details without rereading the thread. jer
Old 19th May 2010, 09:53 PM   #47
moray james is offline moray james  Canada
3M have many other contact adhesives which are vastly superior to Spray 77 you might experiment with them.
moray james
Old 20th May 2010, 03:24 AM   #48
Rather than experimenting, why not contact 3M and ask for their advice?
Old 23rd May 2010, 08:17 PM   #49
3M Scotch Grip # 4693 is a contact which bonds permanently to Mylar (cannot be taken apart) which has a surface tension of about 45 dynes per Cm Sq. that's smoother than polished plate glass. You can thin it and spray over the nylon web on the foil and let dry. I should think that would be a good starting point and the application engineers at 3M can offer other suggestions I am sure.
moray james
Astonishing discoveryHide this!Advertise here!
Astonishing diy music SY Music 12 21st October 2014 03:20 AM
My discovery Ric_LV Subwoofers 1 29th June 2006 10:10 PM
Astonishing! It works! Stocker Everything Else 1 8th April 2005 09:11 PM
Eton Discovery lumanauw Multi-Way 0 2nd June 2004 01:30 AM
Weird discovery with the '95 JLH Lisandro_P Everything Else 4 29th June 2002 05:43 AM
Copyright ©1999-2017 diyAudio
