Planars & Exotics ESL's, planars, and alternative technologies
Stage Accompany: the end or not?
Old 13th February 2012, 10:36 AM   #71
cbrunhaver is offline cbrunhaver  United States
For any interested, I have some SA8535 for sale in the swap meet part of the forum.
Old 13th March 2012, 04:28 PM   #72
Webbie is offline Webbie  Netherlands
Hello,
Stage Accompany will present i.a their new digital amps on de ProLight + Sound 2012 messe.
Greetz Webbie...
Old 7th April 2012, 04:10 AM   #73
gabi37 is offline gabi37  Spain
Default STAGE ACCOMPANY SA8535
Hi, I am Gabriel from Valencia (Spain), the reason for my email, is to see if is still for sale amplifier SA8535, and I would like to know what the price.
Trank you and best regards.
Old 7th April 2012, 06:28 AM   #74
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
for personal affairs, please use PM
moderation
Old 8th April 2012, 02:55 AM   #75
Old 12th October 2013, 10:51 AM   #76
Hello,
I'm very glad that i can inform you that Stage Accompany is still going stronger and stronger every day.
SA released this year three new amps; the DS20 (little brother of the DS50), the SSD420 (4-channel cinema amp) and the HE50 (fan-less, HighEnd amp with no-compromise audiophile components).
All SA amps have for each channel (mono-block) a seperate power supply.
Some more info about the HE50:
The HE50 from the SA High-End Series was developed as a no nonsense High-End amp with the most possible sound quality in mind. The HE50 uses No-Compromise audiophile components such as Low-ESR capacitors and Ultra Low THD / Ultra Low Noise buffers. To accomplish the maximum listening pleasure the HE50 is from a fan-less design. The HE50 is the first High-Power amp in the world with High-End specifications and sound quality.
Excellent sonic performance class-D design amp with built-in DSP, 2 x 2500W @ 4 ohms load.
Switched mode power supplies (one for each channel). 64-bits 96kHz digital processing.
The remote configuration software, Stage Control, is Windows and Mac OS X compatible.
To achieve unsurpassed sound quality you can use the HE50 in combination with the SA M57 (or M59) studio monitor from the Master Series.
Really nothing can beat the HE50 / M57 combo!
TechDoc HE50:
http://www.stageaccompany.com/suppor...50_techdoc.pdf
TechDoc M57:
http://www.stageaccompany.com/suppor...57_techdoc.pdf
Picture of the HE50
Picture of the M57 (with the SA DS50 amp)
Below pictures of the complete SA Digital Series:
- SA SSD420
- SA DS20
- SA DS50
- SA HE50
You can follow Stage Accompany thru their website or facebook:
Offcial Website: Stage Accompany
Official Facebook Page with lots of pictures covering more then three decades of SA equipment: https://www.facebook.com/StageAccompanyBV
Greetz Webbie...
Old 13th October 2013, 08:50 AM   #77
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
interesting devices - thank you for posting this infos.
In the moment a friend of me are looking of a SA8535 Version from the M57 (see small image above).
About the URL
Q: How many different SA8535 Ribbon Compact Drivers are there?
I read follow:
There are seven versions of the SA8535 RCD, see the list below:
SA8535 Standard - basic RCD without horn (e.g. used in the E24).
SA8535 Cinema - same as the standard, but with: different terminals*, stainlees steel mesh screen, horn gasket and screw threads in topplate (for use in the Screen Series).
SA8535 L - same as Cinema, but without screw threads, and with extra topplate inserts for better horizontal diffusion (for use in the GL20).
SA8535 C - standard, but with stainless steel mesh screen and horn (for use in Leader and Champ Series).
SA8535 P - standard, but with spoilers (for active cooling) and horn for use in Performer Series.
SA8535 XL - standard, but with wave shaper for use in AH36.
SA8535 M - same as Cinema (Screen) driver, but with an extra 5mm thick aluminum front plate, and sometimes equipped with Contrad foam wedges (for use in the Master Series, models: M57 and M59).
LSV Achenbach
go to
LSV Dieter Achenbach
offers only the showed version.
Where are to order all the other versions?
which versions are this?
Old 13th October 2013, 10:40 AM   #78
Hello Tiefbassuebertr,
Originally Posted by tiefbassuebertr View Post
i
It's best that you contact Stage Accompany in Holand, SA has no SA-Partner (jet) in Germany.
Go to the contact page on the SA site:
Stage Accompany
Greetz Webbie...
Old 21st October 2013, 01:00 PM   #79
Hello,
After 17 years Prince still uses his "golden" Stage Accompany Performer sets (loudspeakers and amp racks) at the Paisley Park Studios.
Stage Accompany still sell this great unsurpassed PA set.
Below the "evidence" Prince is still using the "golden" SA Performer sets.
The set was used at the Breakfast Experience Pajama Dance Party with 3rdEyeGirl featuring Donna Grantis last Saturday Octobre 19th.
Below one stack of the SA Performer sets used at the "Gold Tour" of Prince.
More information about the "golden" Stage Accompany Performer set can be found at the SA Facebook page and at the news page of Stage Accompany.
Greetz Webbie...
Old 31st December 2013, 09:01 AM   #80
Hello,
Stage Accompany update.
Stage Accompany is going stronger every day!
At the end of this year several exiting things happened at Stage Accompany:
An official Facebook page was build with lots of information about new, older and vintage products. As you may know Stage Accompany has a very rich history that goes back to 1977.
So please have a look at the SA Facebook page (and off course please "like" it): https://www.facebook.com/StageAccompanyBV
Below some of the new products of Stage Accompany:
New phase linear cinema enclosures of the Screen Series, the S31 (full-range) and the SL18 (18"ultra-low sub). All mounted on dollies, custom build for a project in The Netherlands.
Big brother of the M57 (from the Master Series), the M59, made for a customer in Egypt (the white foam is for protecting the finisch of the enclosure).
On the above picture a Dutch disco with 4 x M59 and 4 x AB36 subs, this is really BIG sounding.
More info can be found on the Stage Accompany website and Facebook.
Facebook: https://www.facebook.com/StageAccompanyBV
Greetz Webbie...
Stage Accompany: the end or not?Hide this!Advertise here!
FSL Stage Accompany SA8535 Ribbon Drivers triode4 Swap Meet 4 15th March 2009 05:15 AM
stage accompany ppa-1200 amp dud_wity Solid State 13 6th June 2008 12:09 AM
Replacement parts price increase at Stage Accompany JohanH Planars & Exotics 0 4th September 2006 10:18 AM
Stage Accompany dealership in South Africa. Bas Horneman Everything Else 7 17th November 2004 04:18 PM
FS: Stage Accompany SA8535, Eton, Lambda Dynaudio Bryce H. Swap Meet 0 4th February 2004 05:23 PM
Copyright ©1999-2017 diyAudio
