Planars & Exotics ESL's, planars, and alternative technologies
Anyone know of a US source for ESL toroids?
Old 24th January 2010, 10:12 PM   #51
mavric is offline mavric  United States
mavric's Avatar
Charlie,
any luck on the trannies, that will be the investment, and another, does the dual trans outperform single? If you feel confident on the single, I just might come down there and buy them, or if you have a better suggestion, i am open for lessons. By the way, had a customer, worked at the same place you do, no names, but said he knew you, I will jest say airplanes, either way, nice person, spoke highly of you.
The only true wisdom is in knowing you know nothing.
A wise man does not need advice and a fool won't take it.
Old 24th January 2010, 11:01 PM   #52
CharlieM is offline CharlieM  United States
CharlieM's Avatar
Originally Posted by mavric View Post
Charlie,
I will PM you shortly with latest info.
Old 25th January 2010, 12:55 AM   #53
mavric's Avatar
got it and thank you. kindly check your mail as I have a shopping question on these.
>Borat, please listen and learn.
Old 25th January 2010, 02:23 AM   #54
Liquisonic is offline Liquisonic  United States
Liquisonic's Avatar
Steve is "chuckling" right about now
Have fun, and Cheers
Steve
Old 26th January 2010, 02:41 AM   #55
mavric's Avatar
Charlie, what was the specs on those panels again? I cannot find the post or email anywhere. I am on site a Mccaster, thanks.
Old 22nd May 2010, 11:24 PM   #56
CharlieM's Avatar
Default Found some El-cheapo toroids that work for ESL's
Hello All,
Just updating my thread:
I just found some el-cheapo ($13 each), readily available, Antek AN-0506, 50VA 2x 115v/2x6v toroidal transformers that sound great driving my ESL's!
My fear about dual output windings is the possibility of shorting between the windings and damaging my amps. I hooked up a tandem of these with 6v windings wired parallel and 115v windings wired series and a 1- ohm/10 watt resistor in front, then cringed like hell while I gradually fed them more and more power. I am happy to report that they sound very nice and I cranked out some pretty serious volume too (not all that my amps can deliver but much louder than I ever care to listen again) and nothing bad happened. I have no equipment to measure anything except my ears and my ears say these $13 trannys will fill the bill for hybrid use (mine are crossed over at 275 Hz). Here's the web address for the Antek AN-506 trannys:
Antek - AN-0506
Old 23rd May 2010, 07:19 AM   #57
geraldfryjr is offline geraldfryjr  United States
Awesome report,Charlie,they also have a 360v-0-360v transformer with two 120v primarys as well.
I was considering about trying them out as well using the custom primary technique. jer
Old 23rd May 2010, 04:06 PM   #58
Few is offline Few  United States
Very cool. Thanks for sharing the find.
Few
Old 23rd May 2010, 06:30 PM   #59
mavric's Avatar
Charlie, what was that last jumper for? at the end of the step up? you are right, that was made in Italy, spagetti, lasagna, some noodles. JK, looks just like what we have have, only smaller gauge wire. I am curoius of course on how did yu find this and come to the conclussion that this will work,
Mavric
Old 23rd May 2010, 07:24 PM   #60
CharlieM's Avatar
Mavric
That power supply isn't adjustable but the jumper does allow me to choose between two different output voltages by either using or bypassing he last two diodes and caps in the cirucuit. The schematic is shown on my blogpage-- just something I'm playing around with. Those trannys are equivalent to the 230v trannys that you and I are already using except they have (2) 115v windings instead of a single 230v winding. If you connect those windings in series, you get excactly the same step-up ratio as the trannys we have. The only question was if the insulation between the 115v windings would withstand the voltage without shorting out and they didn't so I'm OK with using them.
Anyone know of a US source for ESL toroids?Hide this!Advertise here!
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 09:19 PM
WTB: 43-0-43 or 46-0-46 Toroids K-amps Swap Meet 3 17th November 2006 09:03 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 01:55 PM
High power toroids source Lupulroz Swap Meet 10 30th July 2003 03:38 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 01:54 PM
