Planars & Exotics ESL's, planars, and alternative technologies
ESL vs Planar Magnetic
Old 31st August 2009, 03:52 PM   #1
Borat is offline Borat  United States
Banned
Default ESL vs Planar Magnetic
what can be said objectively about the tradeoffs between the two technologies ?
please note i am not asking which one is "better" just what are some of the differences ?
for example i have heard that magnepan has stronger bass than martin logan - can such a comment be traced back to the phyics of the technologies involved somehow ?
does any one of the technologies tend to produce less measurable distortion ?
Old 31st August 2009, 05:51 PM   #2
moray james is offline moray james  Canada
most planar magnetic designs (full range like maggies) are single ended. This means the drive is only on one side of the diaphragm and the available linear drive range is very limited. Once the voice coil is out of the small linear range of gap the driving force either gets progressively weaker or stronger depending on diaphragm direction. Bass is a spin off bnefit due to voice coil mass combined with diaphragm tension so as with box speakers the bass is resonant in nature.
ESL's on the other hand have in comparrison a virtually massless diaphragm with balanced drive on both sides. With an ESL the driving forces (both pushing and pulling) are always balanced regardless of the position of the diaphragm between the two stators. This results in distortion levels which can only be matched by a ribbon driver and closely approached by a properly designed horn loaded driver (horn loading permits the driver to stay in its linear range). If you want the lowest distortion possible use either a ribbon or an ESL in conjunction with a sub. Both are suited to DIY construction though at the end of the day an ESL (if well planned) is in my estimation an easier and less expensive project. As an example a used set of Acoustat's can be purchased (in N.A.) for under 5- hundred dollars. This provides you with a full transformer step up interface along with your high voltage supplies. You can then concentrate on building your own panels and even compare them to the stock panels to judge your work. there are many construction threads on this forum for both ESL's as well as ribbons. Hope this helps. PS: the single ended aspect of planar magnetic drivers is not a problem as it results in second harmonic distortion which sounds good in reasonable quantities (as do maggies) but you asked about the lowest distortion and that is in the relm of ESL's and ribbons.
moray james
Old 31st August 2009, 06:16 PM   #3
Banned
i know BG has push pull planar magnetic drivers. i thought the top of the line maggie was also push pull ? well perhaps they're not, but they *could* be made that way in theory. i think the linearity of a push-pull electrostat would still be greater than that of push pull planar-magnetic though.
you know from your description one would think that planar magnetic speakers have no benefit at all - but they have their following. isn't there something they do better ?
Old 1st September 2009, 04:21 AM   #4
please do not read your own bias into my reply. you asked which technology had the lowest distortion and I did my best to answer your question. I do not wish to get into a mud slinging match here. I have owned and enjoyed both styles of drivers and have a pair of each at present. Personally I like ESL's and I think they offer the easiest approach for the DIY enthusiast but that is just my opinion.
As I said planar magnetic designs have drive issues in terms of linear drive range but like any dynamic driver if kept within their linear range they are just that linear. It matters not if you double end a planar magnet design as far as this issue goes though you can increase the range of linear throw with a double sided magnet structure but once past that point the same issues are there. You can not however equal the truly balanced drive of an ESL. This does not mean an isodynamic driver cannot be made to have linear throw in its available range nor that it cannot sound good. I am only trying to make clear what one design has as differences Vs the other.
I did mention several positive aspects of single ended isodynamic drivers which you seem to have overlooked or ignored, that being the production of second harmonic distortion when driven beyond thier linear range. This gives the driver a sweet round sound which is very pleasing, just listen to an old SMG or an MMG and see for yourself they sound excellent. The other benefit of isodynamic drivers is that of the mass of the voice coils which when tweaked along with the diaphragm tension yields bass output which you could not achieve from the same size panel when driven as an ESL. Debates could be had over the quality of this resonant bass but as I have said maggies do sound good so the debate is somewhat moot. I hope that I have been able to make more clear this time what I attempted to tell you in my first post. Just so you still dont think I have a negative bias against isodynamic drivers I codesigned a planar magnetic full range loudspeaker which was taken to market many years ago and was first sold through Sumo in California. That was a planar diaphragm driven by a single 1.25 inch four ohm voicecoil via a very good motor structure. This design went on to be sold under the Museatex bannar as the Melior loudspeaker (there were a number of versions). There is a good discription of this design in an early ninties issue of Audio if you are interested to look. Regards Moray James.
moray james
Old 1st September 2009, 10:11 PM   #5
Banned
good analysis !
what about maximum SPL ?
i am VERY concerned about maximum output.
i ideally would like dance club sound pressure levels - can either or both technologies do this ? is one inherently more or less efficient ?
i am somewhat concerned about efficiency but mostly about ultimate output capacity. if it takes a 10 kilowatt amp - so be it, just as long as it can deliver the goods ?
is efficiency of electrostats frequency dependent ? is it a function of the transformer ?
Old 2nd September 2009, 05:52 AM   #6
CLS is offline CLS  Taiwan
i ideally would like dance club sound pressure levels - ...
So, what led you here?
It's quite odd a SPL guy is searching for ESL or planar speakers.
And, 10kW amp ??
Old 2nd September 2009, 06:02 AM   #7
Compression drivers with horns, 12 inch mids and tapped horn subs, done like dinner bubba.
moray james
Old 2nd September 2009, 06:52 AM   #8
Banned
no i am not interested in dance club levels from dance club speakers
i want dance club levels from ESLs or Planars
why can't it be done ?
Old 2nd September 2009, 08:37 AM   #9
fivestring is offline fivestring  Slovenia
fivestring's Avatar
It can be done with ribbon mids and tweets.
http://www.transmissionaudio.com/
My attempt, 11x2000cm ribbon:[IMG]Click the image to open in full size.[/IMG]
Old 2nd September 2009, 10:13 AM   #10
Calvin is offline Calvin  Germany
Calvin's Avatar
ohh, it can be done but it´s quite hard to achieve such SPLs with ESLs. You have to restrict on a hybrid ESL working >200Hz with considerable membrane area and add a suitable bass.
One problem regards the distribution of SPL over distance and angle.
A tall and wide panel (with sufficient membrane area) will limit the distribution angle to a small value. You can fudge a bit by placing several panels (curved panels in preferance) in parallel, angled to each other.
If the panel is tall it´ll throw a dipolar cylindrical wave into the room which is at first gaining in SPL (up to 3-4m) and then starting to fall off again. As such they are longthrow devices, keeping the SPL up much longer than a point source. The distribution of SPL over distance is more even. This allows to ´drive´ the panel less hard than a point source. But it is more difficult to define a louder dancefloor-area and a softer lounge-area.
Example: A panel distributing in a dipolar cylindrical fashion and which is measured to deliver a SPL of 110dB@4m is equivalent to a point source delivering 122dB@1m (standard measurement distance, where the panel probabely delivers only ~100dB). But while the panel delivers 107dB@8m the point source drops to 104dB. This is a difference of 8dB in SPL-variation (122-104)|(110-100)over a distance of just 7m!
Even though You can reach very high levels of SPL the ESL might not sound as loud, because with very clean signals the ear is less stressed and reacts with less distress (tinnitus). You can stand those high levels longer and with less fatigue (nonetheless are those levels very unhealthy).
The ESL can take high levels of input power indefinetly time because it doesn´t heat up like a voicecoil-driven speaker. The increase in SPL isn´t compressed thermally/powerwise, because there´s no resistance in the drive system! The needed power can be quite low. The cited 110dB@4m were reached with an amplifier output voltage calculating to 50W@4Ohms.
jauu
Calvin
ESL vs Planar MagneticHide this!Advertise here!
I fixed buzz in Sonigistix Monsoon planar magnetic drivers Andersonix Planars & Exotics 35 12th August 2013 07:27 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 02:48 PM
WTB: Raidho FTT75 planar magnetic tweeter luvdunhill Swap Meet 9 7th December 2008 04:51 PM
FS: 1 Pair of Bohlender A1 Planar Magnetic Loudspeakers dvdvideo Swap Meet 0 11th May 2005 06:11 AM
magnetic Pbassred Solid State 6 26th May 2004 01:14 PM
Copyright ©1999-2017 diyAudio
