Planars & Exotics ESL's, planars, and alternative technologies
poor man's magneplanar tweeters.
Old 8th July 2009, 01:09 PM   #21
WrineX is offline WrineX  Netherlands
WrineX's Avatar
i shall make a picture when im back home next week
Old 10th July 2009, 12:21 AM   #22
vegassounder is offline vegassounder  United States
As an owner of a pair of Magnaplaner model SMG-C's I would like to make a suggestion.
In less than a week after purchase the left channel Hi Freq. section burned out.
Turned out that the Audio retailer had replaced the 4 amp fuse with a slo blow version.
Fortunately, the factory took responsibility and re-built at no cost to me.
In your post I see no indication of any current sensing protection.
To determine what value fuse would be needed you might attach a thermocouple temp sensor with tape to the Mylar, inject a 100 hz sine-wave through a current meter into the panel and gradually increase the amplitude until the temp begins to increase and note the current at that point. Installing a fuse with a value about 20% lower than the max. current read under test should protect your panels.
Old 30th July 2009, 12:17 PM   #23
WrineX's Avatar
that is a good idea, but for now im looking for the right sound and a good manner to produce the same panels over and over.
im trying to make one big mid high panel, and wil post pictures of procces so everybody can take a look. and maybe have suggestions.
the previous pannels i used with a woofer of 87 db with active crossove, both panels on each side in series, has around 3.3 Ogm DC wich will roughly be 3.3 x 1.3 4.3 ohm so around the 4.
they if want to let them blend with my woofers i have to put them back 4 dB so that means efficiency is quit good.
Old 30th July 2009, 12:24 PM   #24
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
sometimes we know very little, and sometimes we know too much
Old 7th August 2009, 03:43 AM   #25
Bent is offline Bent  Australia
Looks like a 2m long section may be possible!
I would very much like to build my own ribbon!
I must investigate my local hardware store!
Old 4th March 2014, 10:08 PM   #26
pjstone is offline pjstone  United States
That's it? Wheres the pics? this is a very interesting thread and there should be more!
Anyone do anything with these? Need more pictures!
Phil Stone
Old 5th March 2014, 07:30 AM   #27
WrineX's Avatar
thr pictures where hostes and Im no member of That host Any more dont have backup
Old 5th March 2014, 09:17 AM   #28
geraldfryjr is offline geraldfryjr  United States
This is why I (and others) have always stressed for members to upload the pictures to the forum!!!
The are many great threads that are now with out pictures that I once used to see before!!!
I am sorry to hear that you are without a backup now as I do remember this Great thread.
jer
Old 5th March 2014, 04:30 PM   #29
Few is offline Few  United States
Oooh, too bad! I was really hoping to see the details!
Few
Old 5th March 2014, 04:58 PM   #30
WrineX's Avatar
jer
well i think it was not pissible back then? because i dont like to upload to other server and copy links and stuff, or i just failed to read it WAS possible i will take a look if i can find some of the pictures. but i i must admit i learned allot in the years so if i did make something like this now it would look diferent.
poor man's magneplanar tweeters.Hide this!Advertise here!
Ucd and Magneplanar ecodoppler Class D 2 2nd December 2008 05:14 PM
X250.5 and Magneplanar 20.1 skidave Pass Labs 20 6th November 2008 08:39 PM
FS: Magneplanar .5QR loudspeakers sharpi31 Swap Meet 0 8th July 2007 12:55 PM
8WPC 300B SET and Magneplanar? DrDeville Planars & Exotics 5 29th December 2006 03:57 AM
Active filter for Magneplanar 1.6 Gunders Solid State 14 18th November 2003 07:59 PM
