Planars & Exotics ESL's, planars, and alternative technologies
PIEZO NXT type panel
Old 15th December 2009, 07:11 PM   #481
LineArray is offline LineArray  Germany
OK when looking at the polar plot it seems obvious, it is the
ratio absorbed on the rear ...
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 16th December 2009, 01:15 AM   #482
captainjack is offline captainjack  United States
[QUOTE=LineArray;1996038]Hi Markus,
Those examples should illustrate, that a resonator with high Q
involved in a system is not a problem in itself necessarily.
It depends on how the whole system is designed and aligned as a
network, including all coupled compliances, mass reactances and
resistances.
Well put!!!
Jack
Old 16th December 2009, 01:46 AM   #483
[QUOTE=mkstat;1978181]Hi Mikadosan!
Removing/rounding the corners seems to help to improve this shift of the tangential modes, leaving the problem of lower efficiency of the tangential modes compared to the axial ones.
Rounding the corners has made a very definable difference in my experiments.
Jack
Old 16th December 2009, 11:13 AM   #484
mkstat is offline mkstat  Austria
Default AkAbak
Hi!
In AkAbak you can open the associated dialog (for example DMPanel, Exciter,...) by setting the cursor in the script editor in the line of the function and clicking the "Current Element" button (it's the 7th button from the left).
It seems there is also the possibility to include diffraction effects to the simulation of the radiating element "DMPanel".
I have found an investigation about PU-foam sandwich panels:
Foam Panels.pdf
regards
Markus
Old 17th December 2009, 12:27 PM   #485
Lostcause is offline Lostcause  United Kingdom
Lostcause's Avatar
Really interesting thread
I have about12 of these that I removed from some flat panel NXT iPod speakers last year.... do you think they will be any good for this project?
http://www.diyaudio.com/forums/attac...panel-pair.jpg
They are about 30mm diameter I think
Maybe two picture panels on the wall and a sub...... should be interesting!?
Damn... why didn't I think of that!
Old 17th December 2009, 01:12 PM   #486
el`Ol is offline el`Ol  Germany
In the Visaton-Forum there is currently discussed whether it can be useful to stiffen/flatten end grain balsa with PU glue and a thin foil as cover.
Old 17th December 2009, 05:12 PM   #487
kenpeter is offline kenpeter  United States
Anyone tried pushpull NXT's on either side of the same singular panel?
Or pushpush monopole, magnet backs glued together, abusing twin
opposing panels? What happens in the gap between, does this load
as a diffraction slot terminated circumferential horn (sorta like JBL
Aquarius)?
What happens if you clip two opposing corners, as one might do to
slightly broadband a patch antenna?
What if one were to line array the front and/or back of a panel
with these transducers? Not exactly down the centerline, but
in a line canted slightly offcenter, for resonant diversity...
I now own 16 transducers, and confronted by too many options.
Old 18th December 2009, 06:16 AM   #488
Amina had such a design a few years ago (it's currently not on their homepage anymore).
It's data:
100cm x 20cm x 3,5cm
closed back
180 x 25 HxV dispersion
92dB efficiency
125W (80Hz HP required)
200Hz-20kHz +/-5dB
Old 23rd December 2009, 08:17 PM   #490
http://depatisnet.dpma.de/DepatisNet...es=4&pdfpage=1
This is a link to a german patent from 1927. On the pages 3-4 there
are some drawings showing a method how to excite a showcase using
an electrodynamical exciter. The apparatus is intended to use the
showcase for advertisement with speech and music.
Just for your entertainment ...
Kind regards
www.dipol-audio.de
PIEZO NXT type panelHide this!Advertise here!
Copyright ©1999-2017 diyAudio
