Planars & Exotics ESL's, planars, and alternative technologies
Wire stators, tension, stator bending?
Old 29th August 2008, 10:41 AM   #11
Calvin is offline Calvin  Germany
Calvin's Avatar
its actually very easy to get a esl work.....the hard part is to get it work so good, that its actually better than a dynamic speaker
I was never confident with louvre structures, because I like optically ´transparent´ and eye-pleasing designs. A solution with a number of horizontally positioned parallel beams like Audiostatic uses works equally well, especially with stronger and thicker wires. From Aluminium over steel to plastic are several different and cheap materials useable.
Pic of a smaller panel (80X12cm) featuring H07-VU pvc-coated wire
and 5x5mm steel bars every 80mm.
jauu
Calvin
Old 29th August 2008, 12:55 PM   #12
Charcoal is offline Charcoal  Ukraine
Nevod, have a look at russian audiooprtal.su
THer is big topic re. ESL also. (but I suppose you are already there))))
Wire stators, tension, stator bending?Hide this!Advertise here!
wire stator design oublie Planars & Exotics 36 20th July 2010 03:01 PM
Wire Insulation for Wire stator Audio_idiot Planars & Exotics 6 25th May 2007 11:42 AM
24 gauge CAT 5 wire for stators. dstockwell Planars & Exotics 4 8th January 2006 11:16 PM
Stator alternatives for ESL stators king30 Planars & Exotics 5 1st March 2003 04:31 PM
Copyright ©1999-2017 diyAudio
