Planars & Exotics ESL's, planars, and alternative technologies
maggie PIN specs??
maggie PIN specs??
Old 5th April 2008, 11:39 PM   #1
bear is offline bear
bear's Avatar
Question maggie PIN specs??
Anyone have those pins that go into the speaker connection holes on Magnaplanar speakers?
If so, I could really use the dimensions as measured by a dial caliper or micrometer - or alternately known "factory specs" on the dimensions of the part that goes into the speakers.
Also, are they SOLID PINS?
Do the jacks do the holding??
Any info would be appreciated.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 7th April 2008, 09:02 PM   #2
Ed Holland is offline Ed Holland  England
I have SMGa speakers, and can make some measurements for you if it would help.
There are set screws in the side of the speaker connector that are tightened with a small Allen key. These retain the pin, or... I strip the speaker wire to about twice the length needed in the connector, twist the strands, fold the twisted bare strands back to create a double thickness and feed these into the speaker terminals. The set screws are tightened down to retain the wires. You could also tin the wires with solder, but I have yet to see a problem.
The only difficulty with the method I use would be if one wanted to use speaker cable with a core diameter larger than the terminal post.
Ed
Old 7th April 2008, 11:29 PM   #3
bear's Avatar
Yeah, I would greatly appreciate the exact diameter of the pins, and the approximate length...
_-_-bear
_-_-bear
Old 8th April 2008, 04:09 PM   #4
Sorry - I'll get to it - there was too much happening last night.
You could try drills of various sizes to get the diameter - if you have the speakers to hand, that is...
Ed
Old 9th April 2008, 05:16 AM   #5
OK Bear, found time tonight inbetween fixing the car's ignition and making pastry....
The connector terminal has an 0.1675" hole, as measured by micrometer. A 5/32" drill was a sloppy fit (but would clamp acceptably with the set screw). A 11/65" drill was just oversize.
The hole measured 1" deep
Interestingly the connectors would accept the banana plugs I happened to have in the junk box (the type with 4 sprung leaves over a central pin). They were a good snug fit: No reason to believe that this would be a bad way to go.
Hope that helps,
Ed
Old 11th April 2008, 02:18 PM   #6
bear's Avatar
yep, thanks for the micrometer measurement!
don't have any maggies here, but do have a request for some custom pins!
_-_-bear
_-_-bear
Old 11th April 2008, 04:10 PM   #7
Ahhh, I'm with you now
maggie PIN specs??Hide this!Advertise here!
Modding Maggie SMG's Glowbug Planars & Exotics 1 7th February 2008 04:51 AM
My Maggie livemusic Analogue Source 15 22nd September 2007 08:12 PM
Maggie refurb project radtech Tubes / Valves 17 24th March 2007 12:28 AM
Maggie 1.6 Ohm Reading amkazen Planars & Exotics 2 15th December 2005 02:47 PM
Gabevee's Maggie (MAG1515) percy Tubes / Valves 2 14th September 2004 11:43 PM
Copyright ©1999-2017 diyAudio
