Planars & Exotics ESL's, planars, and alternative technologies
Mating Acoustats with Ribbons
Old 19th March 2010, 08:58 PM   #11
ThomasW is offline ThomasW
Originally Posted by coloradosound View Post
Finally found another set of RD75's of which one of those is also bad.
Providing I repair the bad units, I think I can do something like the Polk
Stereo Dimension Arrays (SDA's).
Any thoughts on correct spacing between RD75's (will probably build
a narrow HF ribbon to fit between the RD75's to cover the top.
Also any thoughts on the response shaping for the crossfeed drivers?
Can't seem to find much info on how the Polk SDA's worked though.
B&G will rebuild the RD75's for a fee. I had one rebuilt a while back cost was $220. Not what I'd consider a DIY project..
The Polk SDA is nothing more than the old Dyna-quad (ambient recovery) design with hot leads from the corresponding sides run to the hot in and a common wire run between the two (-) terminals. Personally I can't imagine this being of any benefit with dipoles.
Old 19th March 2010, 11:07 PM   #12
coloradosound is offline coloradosound  United States
Originally Posted by david yost View Post
If I had 4 BG75's, I would be tempted to try a F and R Ambiopole set-up using 2 X electro-music.com's AmbiophonicDSP crosstalk cancellation program. This would be much more flexible than SDA and probably sound a lot better too!
It sounds like I would have to insert a computer into the system and go through a
sound card?
Old 22nd March 2010, 05:27 PM   #13
I think the SDA was different than the Hafler-Dyna quad setup in that the ambient
recovery was just out of phase signal extracted by running rears from the two (+)
terminals and anything different between the two(+) was out of phase ambient info.
The SDA, If I recall, had attenuated, equalized, inverted signal crossfed to other channel.
So, it sounds like there are two distinct stereo signals crossfed and inverted. The
spacing between the normal signal of inner driver and the outer driver of a channel
set up the delay timing to produce the SDA effect?
I was thinking of some more fairly heavy damping in the BG ribbon part of the system
and leaving just the little felt pads on the electrostat panels, so the electrostat
would be more dipolar, and then become more monopolar in the highs
Mating Acoustats with RibbonsHide this!Advertise here!
Mating a sub to vented bookshelf speakers? GhettoSQ Subwoofers 2 21st May 2006 12:26 PM
Mating a TB 28-847S with Extremis 6.8? Geek Multi-Way 4 2nd October 2005 05:15 AM
Anybody know these ribbons? ronning Multi-Way 6 16th May 2005 06:56 AM
LCY-130 Ribbons Luke123 Planars & Exotics 1 15th May 2005 09:33 PM
How is mating Peerless 850467 w/ Vifa DX25? fishball79 Multi-Way 9 2nd March 2004 02:24 AM
Copyright ©1999-2017 diyAudio
