Planars & Exotics ESL's, planars, and alternative technologies
Cheap ESL bias supply parts
Old 22nd November 2007, 12:24 AM   #1
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Default Cheap ESL bias supply parts
Resistors are $2.50 each, the inverter is $5. Put a voltage doubler or tripler after the inverter and use a resistors in series to make a good bias supply for an ESL.
5 Meg, 2000V resistor:
http://www.goldmine-elec-products.co...?number=G16413
10 Meg, 2000V resistor:
http://www.goldmine-elec-products.co...?number=G16411
18 Meg, 2000V resistor:
http://www.goldmine-elec-products.co...?number=G16374
5VDC in 1000Vrms out DC to AC inverter:
http://www.goldmine-elec-products.co...?number=G16565
12VDC in, -7.5 kVDC out. Use one of these with a couple resistors to divide the voltage to 5kV or less:
http://www.goldmine-elec-products.co...p?number=G1783
I_F
Old 22nd November 2007, 08:07 PM   #2
moray james is offline moray james  Canada
Default Great Heads Up Post!!!
Thanks for taking the time to post this useful information.
moray james
Old 3rd December 2007, 01:26 PM   #3
david yost is offline david yost  United States
Default Inverted ESL
Hello, All:
I am having a problem with one of my Beveridge ESLs, in that on power-on, one of the transducer diaphragms is drawn to one of the stators. Rick Beveridge says that this is a symptom of old age...reduced tension on the Mylar..., and that the other 5 diaphragms are probably not too far behind. Apparently, the built in OTL amps will (or can) go to full +/- 5kV potential when first turned on, and this will draw a weak diaphragm into one of the stators. When this problem first appeared, the diaphragm would release itself after a second or two, but now it clings to the stator until power is switched off. This is accompanied by a loud "whine" while it occurs...not very musical and perhaps destructive.
In an effort to prolong the life of these expensive to service transducers, I was contemplating converting them to transformer driven electrostats like the Beveridge 3, which uses the same high resistance stator design and the same aluminized Mylar diaphragms. In these speakers, the stators carry the bias charge and the low resistance diaphragms carry the audio signal.
OK, so can you guys help me design a bias supply and recommend a suitably audio transformer? And/or does anyone here have a schematic for the Bev 3's?
BTW, my version is the original full range one and doesn't have the built-in sub crossover.
Thanks in advance,
David
Old 3rd December 2007, 02:21 PM   #4
I_Forgot's Avatar
Default Re: Inverted ESL
Originally posted by david yost
Hello, All:
Thanks in advance,
David
This probably ought to be in its own thread... nevermind, I see it already is...
I_F
Old 23rd October 2009, 01:31 AM   #5
audio.ESL is offline audio.ESL  Taiwan
If I use the inverter with 1000Vrms output and feed into the doubler / tripler circuit,should I use a diode with 2000V rating or higher?I am afraid the cheap 1N4007 cannot meet the requirements here.
Thanks.
Old 23rd October 2009, 01:15 PM   #6
Keith Taylor is offline Keith Taylor  Australia
Audio ESL, I found your link did not work for me. Yes I think you would need a diode with a higher PIV than a 1N4007. It needs to be 1.414 times the RMS ac supply voltage plus a safety margin so you would need to be thinking of a rating around 1.5 to 2KV.
Keith
Old 23rd October 2009, 01:40 PM   #7
Keith
Excuse me,may I confirm one point?
For the diode,the voltage across on it in 1.414 times Vrms,
For the capacitor,the voltage across on it is 2.868 times Vrms.
Thanks!
Old 15th January 2011, 06:38 PM   #8
I_Forgot's Avatar
Default Dirt cheap, safe bias supply
Electronic Goldmine has 3VDC in, 2KVDC out modules for $6.
Battery Operated High Voltage Generator-The Electronic Goldmine
All you need is a wall wart and a high voltage resistor to make a small, safe bias supply for your ESL or headphone project.
I_F
Old 16th January 2011, 12:28 AM   #9
bentoronto is offline bentoronto  Canada
Neato, bug-zapper HV! My concern would be that this chopper inverter might be radiating power all around at some noxious audio frequency.
A ladder multiplier with maybe 8 steps is about as simple and cheap a HV supply as anyone could wish.
Either way, you start with some kind of power supply into the multiplier section.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and working on a folded 18-foot Voigt pipe)
Cheap ESL bias supply partsHide this!Advertise here!
Nifty little (cheap ) transformer for bias supply flacoman Tubes / Valves 3 22nd October 2008 12:42 AM
DIY TT on the cheap with used parts makinson1 Analogue Source 3 20th March 2007 02:54 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
cheap parts and a lot of em karma Swap Meet 15 24th August 2004 12:41 AM
