Planars & Exotics ESL's, planars, and alternative technologies
Some Quad els57 questions! - Novice Questions!
Old 4th December 2007, 11:36 PM   #11
arend-jan is offline arend-jan  Netherlands
Hi Frank,
thanks for sharing your mod. I'm going to try it and see what it does. One question, I suppose you don't have the original damping mat that is attached to the rear grill in place with these mods, do you? Did you compare the placement of a single mat with your mod?
Old 5th December 2007, 03:40 AM   #12
frankwm is offline frankwm
Yes - the Hessian mat is still in place - it does have its advantages re: overall rear attenuation...as mentioned I got a new pair of mats from QUAD in '95 along with the other 'bits' - including new rectifier diodes/caps for the transformer..
[I did do a slight mod re: the Hessian though -I used some black nylon curtain 'backing' - very thin (use it for my B&W grilles..) against the rear-grille (held in place using double-sided tape round the edges (looks nicer too) - then I 'anchored' the Hessian by sewing it onto the grille @ various points...it's less 'flappy' that way.
As it was new I also cut it so that it *completely* covered the rear-grille...with the QUAD-type cut various parts of the bottom are left 'exposed'.]
Re: the treble mods - as mentioned firstly, the foam strips are removed - re-seated with clear glue - just near the dust cover/wood-frame junction..this allows the 'flare'.. with the acrylic felt (held in place with double-sided tape on bass panel edges & foam-strip tops + top/bottom plates (I also put some foam in the 'U' of the plates before covering with the felt).
Also, in the rear, I put a felt/foam pad @ the bottom as the treble felt doesn't properly reach that point (& the Cavity Resonance there is pretty bad with the treble felt just loosely fitted, as per original)
[The one-piece thick acrylic felt is also far superior to the previous cotton flock/3 layer affair!]
The only reason folks think of 'tinkering' with this design is a feeling it's 'not quite right'. That 'sensation' disappeared, for me, @ the point all my 'tinkering' stopped..I'm glad to say!
There is also one additional point; The felt behind the treble does provide some 'acoustic ehancement' - so placing the tensioned felt behind the bass panels too tends to make the 3 units more 'integrated'.
Old 5th December 2007, 06:46 AM   #13
lcsaszar is offline lcsaszar  Hungary
Frank, thanks for the details and the sketch, it is clear now. I follow a different approach, though. I completely removed all rear damping, this gives a more transparent, open sound IMHO.
Old 5th December 2007, 09:26 AM   #14
Yes - the panels, on their own, are 'transparent'.
Unfortunately, by removing the various damping, the 'chassis' they are placed in then makes its presence felt even more...
So you get (in no particular order of 'annoyance')..masses of treble diffraction from the front bass sides/top/bottom 'cavity'...rear diffraction/reflections both from the metal grille & wooden treble structure..frame resonances (even worse if you omit the rear grille)...reflections from the huge Transformer...
Have tried all this - but became aware of the 'problems'..but yes..you get 'more air' without damping.
However, 'The Secret' of my method is that the *highly tensioned internal wool 'panel' removes the structural problems - and provides a more 'neutral' setting for the bass panels.
Just one final note:-
The bass felt does need a couple of 'slits' to accomodate the bass terminal...& the felt is best aligned from the top edge (pinned under the top frame..) and the large drawing pins do need slight adjustment to get the felt absolutely 'taut' - like a drum-skin.
If the felt isn't taut then it won't 'dampen' the frame - also you can hear/feel it behind the bass panel - but, tensioned, you can't..
Some Quad els57 questions! - Novice Questions!Hide this!Advertise here!
Utter novice looking for answers to easy questions: shnaggletooth Tubes / Valves 24 23rd August 2009 09:10 AM
A few questions from a total novice. bonescan Tubes / Valves 13 24th March 2009 08:14 PM
Novice questions re: 1st DIY full range project - existing cabinets rbclark Full Range 23 24th August 2007 01:59 AM
Replica Pre QUAD 22 - Questions on mids Scabiko Tubes / Valves 2 27th January 2006 01:28 PM
Questions, questions, from newb DIYer Phatman91624 Multi-Way 41 3rd August 2002 02:52 AM
