Planars & Exotics ESL's, planars, and alternative technologies
ESL Diaphragm coating
Old 9th March 2013, 09:05 AM   #771
gohin is offline gohin
Default quote H202 will decompose
Thanks Bazukaz for that information. I'm going to have a go at removing the new coating because it simply doesn't work in my set up. I think it must be leakage though I can't find it. I may have to make new diaphragms - ouch. I noted earlier in the thread Turtle wax F 21 recommended. May look at that now.
Old 9th March 2013, 12:01 PM   #772
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Originally Posted by alexberg View Post
Licron has urethane binder staticide has acrylic one.
I doubt dilutability of licron in water. Working with alcohol based coatings is a pain in the ... it dries too fast: spraying only
1756-G $298.99 per bottle min 4 to buy ground shipping only
I have successfully diluted Licron crystal(spray) with distilled water to a ratio of 1:1. This slowed drying time a bit. Three very thin layers seem to be required to get sufficient conductivity when applied with a cotton wipe.
It was rather a surprise to me because I didn't expect this to work.
Have tried other substances : isopropanol, ethanol, acetone. They seemed to cause licron to gel and lose conductivity.
Edit : the surface resistance was on a boundary of my measurement equipment , somewhere between 10^10 to 10^11 ohms sq. at relative humidity of 30-40% after 24 hours. The speakers would not play to full volume instantly, and I can hear volume increasing for 10-20 seconds after powering on.
Lukas.
Old 11th March 2013, 01:34 AM   #773
alexberg is offline alexberg
alexberg's Avatar
Well, licron is unobtanium for me mainly due to the shipping and/or distribution - 12 cans min to buy :-(
gohin is not clear on which way staticide did give up and what product he's tried or how he's applied it.
In my case it is OK after 3 years
EDIT: Undiluted product yields rather thick layer: there was similar post about Aussie ESL kit "problems"
Old 25th March 2013, 05:41 PM   #774
Legis is offline Legis  Finland
Legis's Avatar
Is elvamide real PITA to dissolve into ethanol, am I doing something wrong?
I heated the stirring cup in a pot that's slightly filled with water and stirred the mixture of ethanol and elvamide granules for ~20 minutes. The ethanol boiled little for the last 10 minutes so it was really hot. Still I don't see any signs of dissolution.
The alcohol I used is denaturated alcohol, containing 90-95% ethanol and the rest is denaturating alcohols (1-5% propan-2-ol, 2% methyl ethyl ketone and 2% methyl isobutyl ketone).
I bought the Elvamide from here: Electrostatic Speaker Conductive Coating Elvamide 120g | eBay
Old 25th March 2013, 06:33 PM   #775
fperra is offline fperra  United States
I'm guessing it needs to be dissolved in methanol.
Old 25th March 2013, 07:20 PM   #776
Bazukaz's Avatar
It is rather strange. I can say that this elvamide is definitely soluble in ethanol. Maybe you did not give it enough time.
I have tried 96% ethanol that comes from drug stores(the rest is mostly water).
And yeah it took quite a while to dissolve. Maybe an hour or two, I don't remember exactly. The temperature was set to somewhere 50-60 deg celsius. The solution must not come to boiling point.
Gelling time is quite fast and after some time mixture must be heated again to be useable.
Later I have stopped experimenting with it as it seems the resistance is a bit too high and layer too thick compared to some other coatings.
Old 25th March 2013, 08:21 PM   #777
Legis's Avatar
At least the vendor says it's the original Dupont Elvamide. It would help rule out the elvamide quality question if someone had experience with the same ebay vendor (apparently he has sold lots off that stuff).
Did you stirr the mixture the whole time or did you just keep it in the heat? Should the elvamide dissolve if I just place the mixture in a a bottle to 50-60deg water and leave it there for couple of hours, without stirring the solution, or is the constant stirring 100% required? Haven't figured out yet any convenient/cheap automated stirrer.
I was going to dilute the solution very thin, and add carbon black ink to boost conductivity.
Old 25th March 2013, 08:47 PM   #778
Bazukaz's Avatar
I used to shake the bottle every few minutes for quite a long time until it dissolved.
First of all there are several types of nylon which have different moisture content and physical properties.
And yes they are selling DuPont elvamide I think. However there are several grades of elvamide. The one they are selling comes in small squares, see attachment below. Therefore it must be the common grade 8061 with low moisture content(see also table below).
The original coating used by Quad was Calaton. I can not find links any more but I found it is different nylon grade having higher moisture content. It would correspond to Elvamide 8066 perhaps. So my conclusion is the material sold on e-bay is not the same type of nylon as used by quads. I do not know if it works because I decided not to use this on my builds after some trials.
I think it will take a quite high carbon content to affect the resistance considerably, and then uniformity might be difficult to control. You can also try PVA glues instead of elvamide as a binder. If diluted with water to right ratio it will bond to mylar very well.
Lukas.
Old 26th March 2013, 01:10 AM   #779
alexberg's Avatar
That's weird! The one I found dissolved in no time it was a soluble nylon sample directly from manufacturer.
Yet another trick:
http://www.diyaudio.com/forums/plana...ml#post3279696 It's also called fusible web tape for fabric...
FYI http://plastics.dupont.com/plastics/...ide/H85929.pdf
EDIT: soluble nylon (N-methoxymethyl nylon, sold under the name of Calaton CB by ICI)
And even water soluble http://www.toray.com/business/produc...s/che_010.html
ESL Diaphragm coatingHide this!Advertise here!
Diaphragm coating Bazukaz Planars & Exotics 24 9th October 2016 10:41 AM
ESL Diaphragm Coating - HELP GlidingDutchman Planars & Exotics 12 11th October 2014 08:04 PM
PCB coating rs1026 Parts 10 2nd December 2011 11:08 PM
Help with diaphragm coating furly Planars & Exotics 6 17th January 2006 08:23 PM
ESL diaphragm coating I_Forgot Planars & Exotics 58 4th April 2005 05:54 AM
Copyright ©1999-2017 diyAudio
