Planars & Exotics ESL's, planars, and alternative technologies
ESL Diaphragm coating
Old 17th December 2011, 03:26 PM   #481
zweetvoetje is offline zweetvoetje  Netherlands
Someone from the forums PM'd me. I'll have the licron crystal soon
Old 17th December 2011, 03:34 PM   #482
tyu is offline tyu  United States
Well thanks for all the info on the cotings......but i gess i give it some time you guys are nailing it down...6300...this is diff than the Licron Crystal..are thay made by ....techspray.
thanks
Old 17th December 2011, 03:51 PM   #483
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
Default Ordering 6300
Hi Zweetvoetje,
I'll try to order a sample or buy a gallon (or less) of the 6300 and will send you a sample if you want
Best,
Audiofanatic
Be nice to animals.
Old 23rd December 2011, 06:02 AM   #484
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
I have just got a sample of Staticide 6300 and a similar product from a local supplier.
I have some questions for you guys who use this coating:
1. How do you apply it to the diaphragm? (spray, brush, sponge...)
2. Do you dilute it ? (if so, with what)
3. What surface resistance did you get?
In my initial tests I got different resistance readings (5x10^6 and 400x10^6) when coating undiluted with a sponge.
/R
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 23rd December 2011, 07:53 AM   #485
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
I put just a few tiny drops of 6300 on the diaphragm surface and wipe the surface with a damp sponge. I never try to measure its resistance though.
Since it's water base, you can dilute it with water if you want to.
Wachara C.
Old 23rd December 2011, 08:08 AM   #486
SM7UYJ's Avatar
Wachara:
When you say damp sponge, it is water or S 6300 you have "in" the sponge?
If it is water, then you dilute the soultion when whiping it on the Mylar right?
/R
- A. Kindsvater
Old 23rd December 2011, 08:16 AM   #487
I actually damp the spong with water. I guess I did dilute the solution a bit when wiping with this damp sponge.
Wachara C.
Old 23rd December 2011, 05:08 PM   #488
alexberg is offline alexberg
alexberg's Avatar
/R
That might not be my "know-how" but rather collective wisdom (Star Trek, sorry cant help it) I've used. And it's probably posted elsewhere around And forgive me if it's your recipe I am prescribing
That's what I did
I've applied it with the polyurethane foam wedge shaped brush.
Further steps are not that simple.
First of all you need to decide what resistance you need
Second - make samples as many of fellow DIYers have done: paint a strip across mylar strip (decreased and activated - the latter was described as well). After an hour or so (you may use hot air to speedup the process, remember?) using simple stencil made of paper, paint two stripes by graphite 33 over the coated area. Now you've got "Zebra": two highly conductive strips reliably connected to the coating. Let's say 10 cm(4") wide stripe of Mylar, 5 cm wide painted 6300 stripe across, two graphite stripes 1 cm wide and 1 cm wide coated stripe (graphite free) in between. Using DVM as ampere! meter! (usually DVM has fixed input resistance 1Meg Ohm (read specs)) apply around 1kV (using as many precautions as one possibly can) and calculate the resistance using Ohm's law. Readings for Ohm per square can be easily be derived as R(U/I)*Width(10cm)/Length(1cm)
Do not try to use high voltage - edges of graphite stripes are really sharp, so corona discharge develops pretty easily (ozone smell and hissing if you are really reckless) thus screwing your measurements.
That's it - make few test stripes as described with the different dilution factor.
Choose the solution you consider to be the appropriate one.
Undiluted 6300 yields too thick of a coating...
One of the ways to check thickness is to cut coated film preferably at 45 deg angle and use microscope. Knowing the film thickness you can easily estimate the one of the coating.
"Practice makes it perfect" together with the Lord of Darkness who resides in the details
Happy trying!
Alex
Edit: As soon as you can produce reproducible (resistance wise) coating you are ready to go...
Old 24th December 2011, 10:16 AM   #489
SM7UYJ's Avatar
When my coating samples had dried for two days, the results were a lot better!
My test setup is:
- PSU 1200V DC
- 10MOhm voltmeter
- Multimeter with 10kV high voltage probe
- DIY surface probe (17x80mm copper rods spaced 5mm for 1:16)
When I measure the Staticide coated Mylar I get ~1 GOhm square - perfect for my needs!
I'm expecting a delivery on tuesday of a ESD procuct I can mix with Elvamide. As heat treated Elvamide sticks like tar to Mylar I would like to use this on panels that are hard to split and recoat.
/R
- A. Kindsvater
Old 24th December 2011, 04:02 PM   #490
alexberg's Avatar
SM7UYJ
Sounds great. Have you done adhesion test?
With the probe you are using it's near impossible to have reliable contact along the edge. So the painted electrode is better.
Use force drying - it's allowed by TDS: chinsettawong mentioned that naturally dried coating is kinda tacky. I have not observed that though.
The nice thing about 6300 is the very fast resistance recovery after moisture exposure: try to breathe on the coating and measure the resistance change over time...
I tried 2 varieties of soluble polyamide - none had good adhesion whatsoever.
Try moisture test on Elvamide...
ESL Diaphragm coatingHide this!Advertise here!
Diaphragm coating Bazukaz Planars & Exotics 24 9th October 2016 11:41 AM
ESL Diaphragm Coating - HELP GlidingDutchman Planars & Exotics 12 11th October 2014 09:04 PM
PCB coating rs1026 Parts 10 3rd December 2011 12:08 AM
Help with diaphragm coating furly Planars & Exotics 6 17th January 2006 09:23 PM
ESL diaphragm coating I_Forgot Planars & Exotics 58 4th April 2005 06:54 AM
Copyright ©1999-2017 diyAudio
