Planars & Exotics ESL's, planars, and alternative technologies
acoustst 2+1 biamp?
acoustst 2+1 biamp?
Old 25th July 2007, 02:55 PM   #1
Williams Audio is offline Williams Audio  Jamaica
Default acoustst 2+1 biamp?
Hello all,
I got a pair of acoustat 2+1, after taking off the HPF xover and separating between the trafos inputs, the hi freq and low freq, I am wondering if I can drive the 2 audio trafos as bi amp with 2 pwr amp and an active xover. Is not clear to me if the so called low freq trafo works as a filter as well or will
deliver a full band freq response.
Best regards Williams
williams audio
Old 25th July 2007, 03:17 PM   #2
frank ziel is offline frank ziel  Germany
here you can read all about the idea behind the
magnetic cinetic interface for acoustats:
http://v3.espacenet.com/textdoc?DB=E...=EP0057215&F=0
Frank
Old 26th July 2007, 04:03 AM   #3
hi frank,
thanks for your replay,
the site you are refering to is a patent and a lot of pages are
missing out, do you know some thing else?
best regards williams
williams audio
Old 26th July 2007, 03:40 PM   #4
Hi Williams
If you click to the tab "Original document" (top right)
you can read everything about the two transformers and the
great idea behind it. You can zoom to read better,
100% is nice.
Please mail if you have any difficulties.
Best Regards
Frank
Old 27th July 2007, 07:54 AM   #5
hi Frank,
thanks for your replay once again.
i do encounter problems reading and trying to save this document.
if you have it in a normal form i will like very much to have it.
i did succeed to read a small part of it and it looks that bi amp
is not the subject, may be is no need for it, i think so.
so if you can help me to receive the full document, thanks in advance.
best regards
Williams
williams audio
Old 27th July 2007, 11:14 AM   #6
diyAudio Member RIP
Having perused said patent article the answer to the question
above is yes and no. Yes you can drive each transformer with a
separate amplifier and no you should not use an active crossover.
Assuming the speaker follows the principles of the article.
/sreten.
Old 27th July 2007, 06:28 PM   #7
it is strange not be able to use an active xover; if the hpfilter is disconnected from the hi freq. trafo, after all is only a hpfilter it will be compensated by the active xover filter at the pwr amp input and it will function a some. but may be you are right, i can't read the patent article so this is only what i think.
The question is there is any benefit result by bi amp?
best regards
Williams
williams audio
Old 28th July 2007, 04:40 PM   #8
Audiofool is offline Audiofool  Israel
Hello Williams.
At the top right of the page you will see a list of "Also published as:" patents list.
Choose the link to US4323736 (A1) and from there you will have access to the "Description" tab, that covers the background to the patent in depth : really interesting stuff !
http://v3.espacenet.com/textdes?DB=E...&QPN=US4323736
Don't forget that this is not a usual B-amping scenario : the transformers secondaries and filters are connected in parallel to a single driver, and I guess Strickland figured out the relations between all elements.
However, it seems you still can benefit from bi-amping from the amplifiers point of view, as the high pass amp will be free from the task of driving the low frequency input : a huge advantage which is not possible with a single step-up transformer.
Good luck !
J.B
Old 30th July 2007, 05:42 PM   #9
diyAudio Member RIP
hi,
go to the document link
Below the title click on "Original Document", then above "Save Full Document".
/sreten.
edit :as far as I can tell removing the LPF will not be a good idea.
acoustst 2+1 biamp?Hide this!Advertise here!
5W Zen for biamp tweeter Kanga Pass Labs 16 2nd February 2010 10:58 PM
DIY Biamp project docz Full Range 1 25th November 2004 07:50 PM
Biamp: Wich fc ? Higo Multi-Way 18 5th August 2003 12:24 PM
To Biamp or not to Biamp, that is the question??????? Apogee Pass Labs 70 12th July 2002 12:34 AM
biamp with active x-over Fossil Solid State 9 10th October 2001 02:10 AM
Copyright ©1999-2017 diyAudio
