Planars & Exotics ESL's, planars, and alternative technologies
NEO8-PDR Dipole Computer Speakers
Old 17th July 2007, 01:11 AM   #1
SsZERO is offline SsZERO
Send a message via ICQ to SsZERO Send a message via AIM to SsZERO
Default NEO8-PDR Dipole Computer Speakers
I think the NEO8 driver would be great as a computer speaker, with both music and game sound. I'd like some advice on how to implement it. Ideally it would be a 2-way system, but there seems to be some disagreement as far as the NEO-8 being good at sound > 10KHz. I can hear pretty well, up to 19KHz and I like somewhat bright and airy highs in my music and sound effects. It sounds dull to me without clean highs.
So can I get some recommendations on what to pair with the NEO8 to make a great sounding computer speaker? I will be driving them with the Keiga 3100 2.1-ch amp available at madisound.
Thanks!
Old 24th July 2007, 12:42 AM   #2
MaVo is offline MaVo  Germany
Maybe thats no good answer from me, but why dont you try the Neo without tweeter and judge by your own impression if you need a tweeter? Or just use a notch filter for the cavity resonance instead of an additional driver.
Old 24th July 2007, 12:56 AM   #3
The thing is, the NEO8 only goes down to 700 Hz and my subwoofer only goes up to 120 Hz. Wouldn't it be better to have a driver that can fill in that gap between say 100 to 700 Hz? I was thinking about using a 5.25" driver and maybe cross it over around 2000 Hz, which would let the NEO8 handle the higher frequency sounds. Would the NEO8 alone sound decent as a "full range" speaker if used with a subwoofer?
Old 9th August 2007, 06:51 PM   #4
NurEinTier is offline NurEinTier  Europe
A decent 8" wooferr goes up to 700hz.
Unless you're a bass freak one or two 8" woofers should give enough lows, no need for a sub.
If you want to cross at 2000 go with the neo3.
Dipool neo3 can be crossed at 2000 and would be better at the higher frequencies than the neo8.
Not many 8" woofers like to go up to 2000 though.
Better to use one or two 4", 5" down to 250-300 and woofer or sub.
A 3-way is much more diffuicult and expensive though.
Old 10th August 2007, 02:13 PM   #5
bwaslo is offline bwaslo  United States
bwaslo's Avatar
Or you could shop ebay for a used Monsoon M700 or M1000 set. I've gotten several for under $60 per set. They have panels that go down to 250Hz and a woofer that works below that, along with EQ to deal with the 6dB/octave dipole slope (you'll want to mimic that if you go with NEO8s).
Old 10th August 2007, 02:43 PM   #6
Daveis is offline Daveis  United States
Neo8 looks like a good dedicated upper midrange in a 3-way design.
Even the 40" and larger BG ribbons lose out quickly below 500hz.
I would predict that it would make your speakers sound "thin" if crossed over below 800hz.
Old 11th August 2007, 11:30 AM   #7
http://www.samsontech.com/products/p...fm?prodID=1778
http://www.adam-audio.com/german/professional/
http://www.behringer.com/B3030A/index.cfm?lang=eng
Maybe a studiomonitor as an alternative.
That adam a7 is well regarded.
Been thinking about it myself.
Just ad a sub and you're done.
http://www.adam-audio.com/german/downloads/magazine.htm
NEO8-PDR Dipole Computer SpeakersHide this!Advertise here!
Dipole speakers oon_the_kid Multi-Way 7 13th January 2009 01:21 AM
1st diy computer speakers! jonnyq Multi-Way 22 12th April 2006 11:51 PM
NEO3 and NEO8 as dipole or in chamber? henriksommer Multi-Way 7 17th May 2004 11:34 PM
B&G NEO3 and NEO8 in Martin Logan speakers ?? cph2000 Multi-Way 3 7th March 2004 09:03 PM
What computer speakers you ppl use? downhere Multi-Way 16 30th October 2001 10:48 PM
Copyright ©1999-2017 diyAudio
