Planars & Exotics ESL's, planars, and alternative technologies
Straightening a warped stator
Old 7th July 2007, 03:13 AM   #1
jnb is offline jnb  Australia
Default Straightening a warped stator
I ordered 4 stators of 1200 x 240mm and one looks like this. How can I flatten it?
Old 8th July 2007, 07:11 AM   #2
ak_47_boy is offline ak_47_boy  Canada
You could make a frame. It would be very hard to fix that perfectly.
Edit: Sandwich it between two pieces of 3/4" plywood and park you car on it overnight.
Old 8th July 2007, 07:36 AM   #3
moray james is offline moray james  Canada
Default Why don't you...
talk to a pro at an auto body shop. It won't cost to ask.
moray james
Old 9th July 2007, 11:37 PM   #4
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Ask someone who works in a machine shop or sheetmetal shop, as they will have the press to bend it back and the flat surface to check it against.
(Just holding it flat won't work: It needs to be taken past the yield point.)
Old 10th July 2007, 12:32 AM   #5
On Hiatus
SY's Avatar
You may find that when you assemble it into a sandwich under pressure, the resulting cell is flat. My stators have a noticeable bow unassembled, which straightened out beautifully when I glued the whole shmeer together.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th July 2007, 02:00 AM   #6
Great to hear that close enough may be OK. The other three have a slight and simple warp which I suspected would work well enough.
I was thinking of parking my car on it like ak_47_boy suggested. I somehow knew what Tosh says is true, and I hope that by leaving it for a while the thermal cycling may give it what it needs.
I guess since I was planning to use 1/16" spacing and foam double sided tape, and due to my inexperience I was afraid it wouldn't be good enough.
Straightening a warped statorHide this!Advertise here!
You just can't win.. Warped LP's. Jeb-D. Analogue Source 26 24th October 2007 07:09 AM
Help - heatsinks warped bpetrus Everything Else 9 12th May 2004 10:29 PM
Warped records Stanislav Analogue Source 10 5th March 2003 12:02 AM
Copyright ©1999-2017 diyAudio
