Removing sharp perforation edges on stators with ferric chloride Removing sharp perforation edges on stators with ferric chloride - Page 3 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 7th July 2007, 03:29 AM   #21
Audio_idiot is offline Audio_idiot  Malaysia
Is this the electro polishing we are talkng about now??
http://www3.telus.net/public/aschoep...lyticrust.html
Cheers
Audio_Idiot
Old 7th July 2007, 11:30 PM   #22
bear is offline bear
expert in tautology
bear's Avatar
Default Re: Perforated Al ESL stator prep
Originally posted by glorocks
The panel should be first wet sanded with 4-600 grit "wet or dry" emory paper. Use a soft rubber sanding block. This may be enough to knock down the ridges.
<edit>
That would not be emory paper.
Either SiC, silicon carbide, or else aluminum oxide if it is wet or dry.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 8th July 2007, 04:02 AM   #23
glorocks is offline glorocks  United States
Bear, you're right. Back in my day, we called wet sanding SiC abrasive papers "emory" paper. I'll be more careful in the future.
Old 8th July 2007, 04:02 AM   #24
Regardless of what we call the abrasive, the important point is to use liberal amounts of water to keep the abrasive from clogging up. A soft backing for the abrasive system, such as a heavy sponge or a soft grout float will allow you to break down the edges without the use of chemicals.
Old 8th July 2007, 12:07 PM   #25
auplater is offline auplater  United States
auplater's Avatar
Default Electropolishing AL
Using NaOH (lye) will usually leave a grey or black smut on the aluminum... it will etch but not polish the edges... maybe not the effect you want...
Commercial epolish uses decidedly unfriendly acids and high current density for the desired effect... typically Sulfuric/HF solutions ... or phosphoric-chromic-sulfuric-nitric mixes at 100 - 200 asf... not gonna post any formulas as someone will get hurt...
Brite dipping would also work... but again... find an anodizer and let them deal with the hazards...
Lye won't form an oxide, it'll keep etching till all the OH is exhausted and will leave the aforementioned smut.
Best to either find a commercial plating/finishing shop and see if they'll do it... or live with a crappy half-baked NaOH etch and then sand the results... <- would not be my choice.
Why not pour lye down the drain? That's what Drano is... and most other drain cleaners (excepting the sulfuric acid or enzyme types)... won't hurt pvc or copper plumbing... and it'll clean out all the hair and organic crud from years of mis-use...
btw... emery IS aluminum oxide.... http://en.wikipedia.org/wiki/Emery_(mineral)
Emory is a university in Atlanta Ga.
I'd leave the chemistry to chemists..
John L
"I've forgotten more than I care to remember" The Last Conspirators
Old 8th July 2007, 01:08 PM   #26
bigwill is offline bigwill  United Kingdom
Yeah, I'm now thinking of just countersinking every hole and sanding it with very fine whatever-paper.
However, I performed an experiment in which I dipped an aluminium candle holder in lye. The black smut readily washes off and the resulting surface does not look corroded.. In fact it looks pretty good.
Old 8th July 2007, 01:55 PM   #27
auplater's Avatar
Default etching
If it works, and gives you what you want.. go for it...
The smut problem depends on the alloy... low alloy Al (6061, 2000 series) aren't too big of a problem, especially if you can wipe the smut off and no further finishing is required. You can also polish up the surface afterwards with Softscrub (w/o the bleach) or even Ajax or Comet.. (or a pumice slurry)
John L.
Old 8th July 2007, 04:02 PM   #28
Isn't Al just Al? What is it alloyed with?
Old 8th July 2007, 11:12 PM   #29
auplater's Avatar
Not at all... pure aluminum is almost never found... most is 6061, alloyed with copper, silicon, and magnesium to make it heat treatable...
http://www.suppliersonline.com/prope.../6061.asp#Spec
other alloys include 202x copper-magnesium series, 7xxx series, etc... pure Al is extremely soft and of limited use... I believe spec'd 1199... 1000 series is the purest
http://mdmetric.com/tech/alumcomp.htm
All these alloys behave very differentluy and have dramatic differences in tensile stregth, heat treatability, surface properties, etc.
most of the black smut left is copper, iron, silicon and other insoluble crud... it plays havoc in the metal finishing industry w/o the proper post treatments (hence the nitric, HF, etc. ) post-etch rinses
FWIW
John L.
Old 9th July 2007, 08:49 PM   #30
expert in tautology
bear's Avatar
Auplater knows his stuff in this department.
Although I have never seen a "smut" build up on aluminum, that doesn't mean that it wouldn't happen.
As far as pouring lye down the drain, it could simply etch right through copper or brass sink traps. Probably wouldn't, and just leave it bright and shiny?
Guess it depends somewhat on the amount and concentration...
Ok, flush liberally with water when ur done...
_-_-bear
_-_-bear
Removing sharp perforation edges on stators with ferric chlorideHide this!Advertise here!
Alu stators, holes/perforation aligned? bentl Planars & Exotics 2 22nd April 2009 08:00 PM
MDF edges and screws rinx Multi-Way 32 16th August 2008 03:36 PM
Help: ferrous chloride/water ratio theAnonymous1 Everything Else 41 30th March 2007 08:50 AM
ferric chloride hacknet Parts 27 19th December 2002 07:41 PM
Copyright ©1999-2017 diyAudio
