Planars & Exotics ESL's, planars, and alternative technologies
Shipping Great Heils
Old 18th April 2007, 11:00 AM   #11
SilverFox is offline SilverFox  United States
Originally posted by Brian Beck
That would explain it!
Or "make it"? See the many ESL and ribbon designs discussed in this category.
Wait a minute, Brian. You're not getting off that easy.
Are you telling me that of ALL the tweeters being manufactured today, there are NONE that equal the capabilities and sound of the Heil?
If you can't give even ONE brand and model of one that does, then you're trying to say that the ONLY way to equal the Heil is to... "make it yourself"?
Does my skepticism show?
Mark
Old 20th April 2007, 11:48 PM   #12
Brian Beck is offline Brian Beck  United States
Brian Beck's Avatar
Sorry, Iím not tending to the forum much these daysÖ
Well, youíve set up criteria to favor the Heil drivers, instead of asking what combination of drivers might sound better (always a dicey question). If you require a single driver that goes down to 800 Hz (not a good place for a cross-over, IMO, but thatís another question), and is dipolar, then your choices ARE limited. If you allow the possibility of domes Ďn cones, then there are numerous choices from Tymphany/Peerless/V-Line/Vifa, Seas, ScanSpeak, etc. I like what Iíve heard from several variants of the ring radiator tweeter, for example.
But this is not a thread about domes Ďn cones. As you might have guessed, Iím an ESL fan. Thatís why I suggested considering DIY ESLs, which arenít as hard to make as it might seem. This IS a DIY forum after all. You can make ESLs almost full-range and keep the crossover far away from the critical 800Hz to 1000Hz region. There are many informative threads here on that subject. If you want to buy a ready-made ESL driver, there are some drivers available from a few smaller companies - again these threads will tell you about them. Another choice is to use ribbons or planar magnetic drivers, like the Bohlender Graebener drivers.
A thought on the sound of the Heil tweeters: My experience is only with the original Heil drivers. I understand that they used polyethylene film in the diaphragm. Later Heil drivers used other kinds of polymers, and the sound was notably different (I am told). The Heil relies more on the bending properties of plastic than most drivers do. Every crease in every fold in the diaphragm must deform to make sound. Plastics like polyethylene have a characteristic in this kind of use that might enter into the sound: hysteresis. Hysteresis means that the material has memory; it will tend to stay where you set it, or, said another way, will not restore to exactly the starting position when the force is removed. I think this may have contributed to the plastic-y glare and lack of inner detail that some heard with the original Heil driver. All drivers have some degree of hysteresis, but modern cones Ďn domes have gotten a lot better, and ESLs nearly vanquish hysteresis distortion by virtue of the air impedance dominating over material properties.
If you like the Heils, then you certainly donít need to convince anyone else, but you did ask the question.
Brian
Shipping Great HeilsHide this!Advertise here!
ess GREAT HEILS are back made in usa Planars & Exotics 0 12th March 2009 10:08 PM
FS Gainclone Great Chassis, Potted toroidal, great sound PHilgeman Swap Meet 4 2nd May 2006 01:20 PM
Heils again! Tempest Classic? Which ones? Chrisssssssss Planars & Exotics 7 12th April 2006 08:59 AM
Has anyone seen these new Heils? markp Planars & Exotics 5 21st December 2004 09:22 AM
Copyright ©1999-2017 diyAudio
