| PC Based Computer music servers, crossovers, and equalization |
#2011 | |
#2012 | |
Location: Southern Italy - London (UK) - Philadelphia (US)
.wavpcm: A non-standard, but widely used, variant of .wav. Some applications cannot read a standard WAV file header for PCM-encoded data with sample-size greater than 16-bits or with more than two channels, but can read a non-standard WAV header. It is likely that such applications will eventually be updated to support the standard header, but in the mean time, this SoX format can be used to create files with the non-standard header that should work with these applications. (Note that SoX will automatically detect and read WAV files with the non-standard header.) Best Wishes Pietro |
#2013 |
I do not know which wavs you have. Both types have the wav suffix. You can check via sox -V your.wav -n
Code:
sox INFO formats: detected file format type `wav' Code:
sox INFO formats: detected file format type `wav' sox INFO wav: EXTENSIBLE |
#2014 |
If you want standard pcm wave file, just do it via mplayer.
# mplayer -ao pcm:file=output.wav input.etc checking file format for sure: # file output.wav |
#2015 |
Is anyone kind enough to provide a step by step idiots guide to setup a good Linux audio system ?
I found one for Windows (very complete & idiot proof but in French) but only scattered infos on Linux from various web sites with various level of details. |
#2016 |
Not exactly what you want, but relevant:
http://cort.as/1Wll |
#2017 | |
#2018 |
Interesting - usb class 2.0 gadget driver :-) Can be pretty handy at times.
Linux USB development and users () |
| Page generated in 0.11523 seconds (80.31% PHP - 19.69% MySQL) with 11 queries |
