| PC Based Computer music servers, crossovers, and equalization |
#1511 | ||
#1512 | |
To get back on-topic; Nothing beats controlling your HTPC from the sofa and be able to access all my music from one centralized location. Removable media is dead. |
#1513 |
Hi folks.
I just started to get my Linux Audio Wiki back in place. It'll take a while to get it filled up again of course. Linux Audio Wiki I started with a small article about a no frill command line player approach, which will sound better as most of the stuff you've listened on any OS. ( phofman that's nothing for you Any feedback welcome! Cheers
::: Squeezebox Touch Toolbox 3.0 and more ::: by soundcheck |
#1514 |
Thanks Soundcheck!
#1515 |
Soundcheck,
Thanks for your work. I will check your wiki regularly. Sound has been my biggest problem with Linux. Thanks Jim |
#1516 |
Good work on the wiki Soundcheck. All in all this thread has been a great source of info.
I am now using mpd and controlling it through mpod (a free app.though I would pay for it) on an itouch and through minion as a firefox addon. MPD is a challenge but worth it in the end..at the moment I am using Ubuntu Karmic but might well move over to Linux Mint. The whole process has been a good learning curve for me wrt linux and I now dual boot my new laptop and use it as a development machine for when I am away. My intention is to use my usb dac but that bit isn't integrated as of yet and I am still using mp3 files. I have settled on dbpoweramp (even though there is a charge) to rip my collection. My question is how do I get MPD and ALSA to play flac and / or wav files? I keep hunting through the wiki but can't work it out. Maybe one of you MPD linux experts can help? Thanks. |
#1517 |
Hi folks.
Would be nice if anybody could try my commandline player example in the Wiki. I'd be interested if 1. it s manageble to do for the "average" user 2. it delivers the soundquality I am promising. Please try example 8. @ackcheng: You're running Pure Music ( the current ultimate player (iTunes-plugin) on a MAC) right? Would be nice if you could give it a try. Today i fixed two amixer init-scripts for the HDSP 9632. This way there is no need to use HDSPmixer/HDSPconf for initializing the card. This way you can run it in recovery mode. Let me know if you are interested. Later on I'll put them on the Wiki anyhow. Cheers
#1518 |
So you need a dummy? That's an easy task for me
I just followed your advices, with the exception I only needed to install schedtool, the other programs are already present, as well as the rt-kernel. I adjusted the correct alsa device as well. But, if I then type 'sudo eca440h' I get an 'command not found' error. (Yes, I did a reboot...) when running eca440h as the current user, I get: /dev/shm/<myfile.wav>ERROR: could not set PID 5385 to F: SCHED_FIFO - Operation not permitted Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog Last edited by Onvinyl; 21st March 2010 at 07:23 PM. Reason: refinement |
#1519 |
I wouldn't call it dummy? I need a/some serious trustworthy non-biased tester(s). Your issue: Did you configure /etc/security/limits.conf as described? Do a more /etc/security/limits.conf if you find those 3 lines in that file? After you configured those lines you need to reboot. As user root you wouldn't have these limitations. ( sudo su) Don't forget to copy the users .bashrc to /root, otherwise you won't be able to run that eca.. alias as root and if you login into recovery mode. BTW: I'd suggest to have these kind of discussions which refer to a specific Wiki page in the "Wiki" section. As you might know each Wiki page comes with separate thread. This way you can constructively develop that specific wiki further as a community effort. Cheers
#1520 | |
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| FilleMang |
| Page generated in 0.14948 seconds (76.68% PHP - 23.32% MySQL) with 11 queries |
