| PC Based Computer music servers, crossovers, and equalization |
#1431 | |
Uli |
#1432 | |
I have a Squeezebox at home since a week (paid 86 €). It's not playing yet. I had a look at wireless network under Linux and I estimate that it will take me a couple of months at least to get that going (or not). So using wires is preferential. How much quality loss would that give? Galvanic isolation with optical fiber could be obtained in the ethernet cable if that is an absolute must (cost ~100€). Another question is about the volume control: do you fully rely on the software control of the SqueezeCentre and is the quality OK? Does it use 24 bits? Kind regards, Eddie |
#1433 |
a wireless router is all you need for a wireless connection. I don't see why you need to deal with Linux wireless. Perhaps you can explain more.
The volume control in the Squeexeboxes I have used is digital and I would not use them in a performance application. You can defeat the volume control.
Demian Martin Product Design Services |
#1434 |
Banned
Does the Squeezebox support the RIFF tag format that can be used for WAV files?
Is Tag&Rename the best editor for putting RIFF tags on WAV files? |
#1435 | |
I am using a Linux PC since a few years for WAV-playback under a rt-kernel. Sounds great, and a big improvement was achieved by replacing the hardware volume control (an expensive stepped attenuator in my case) with a software control that first upsamples to 24 bit. From what I read about the Squeezebox I am not shure that it is using this method. Its build-in Wolfson DAC can handle 24 bit as far as I know. If you have any information on this I would be happy to receive it. The wireless connection is a completely different story. It is available on my motherboard. However, I am not familiar with this and after spending three evenings of reading I was left with two huge documents on how to install it. These documents were so different that I had no idea anymore what to do. I have already wasted enormous amounts of time in trying to install Linux and applications under it. I am totally fed up with that. So the alternative is simple, I will use cables. Kind regards, Eddie |
#1436 |
Hi Eddie.
Sounds like you're still not used to Linux. ![]() In your current case your problem has nothing to do with Linux. It is your lack of knowledge about "networking" and "wireless lan" and not to forget that you try to get the "hacker" version of Squeezebox working. With a controller at hand things are much easier. The key issue is to get the initial networking configured within SBR and to get your router configured properly. Checkout this page:: GettingStarted Net-UDAP To get the UDAP tool going do this: Code:
sudo su apt-get install subversion cd /usr/src svn co http://projects.robinbowes.com/svn/Net-UDAP/branches/1.0.x cd 1.0.x/scripts ./udap_shell.pl UDAP> discover (make sure the SBR is config mode - slow blinking red led) list configure 1 ( whats your client? change "1" accordingly) Note a key challenge is to configure the correct encryption which is used on your WLAN E.g. wireless (wep ) wireless - wep - config : --------------------------------- Code:
set interface=0 hostname=squeeze1 squeezecenter_name="server-hostname" server_address=192.XXX.X.XXX squeezecenter_address=192.XXX.X.XXX lan_gateway=192.XXX.X.1 lan_subnet_mask=255.255.255.0 wireless_mode=0 wireless_region_id=14 wireless_SSID="your rwireless network name" wireless_keylen=1 wireless_wep_key_0="wep-key" wireless_wep_on=1 wireless_channel=11 Change ip adresses according to your setup. Note: it is important that you own a router where it is possible to reserve certain ip-adresses for certain clients (MAC addresses). Otherwise the whole thing won't work. You can't allow to have changing addresses on the LAN. Cheers
::: Squeezebox Touch Toolbox and more ::: by soundcheck |
#1437 |
Hi folks.
I figured out a new thing. "squeezeslave" a virtual squeezeclient. That one lets your PC run as virtual squeezebox receiver (great for FitPc headless) and overall audio control of your (audio)-PCs SqueezeSlave - SqueezeboxWiki ( Linux build instructions are OK) Start command - example: Code:
./squeezeslave -k20 -esoftsqueeze3 -M"/var/log/squeeze.log" -o0 192.XXX.0.XXX See attached picture which shows the two clients ( on SBR and one squeezeslave) on iPeng. Cheers
#1438 |
[alsa-devel] [PATCH 1/1] Added functionality for E-mu 0404USB/0202USB/TrackerPre
Looks like E-MU USB sound cards support is to move ahead. |
#1439 | |
#1440 |
I looked at squeezeslave a few months ago. It seemed to be limited to 16 bit and OSS interface. Has it been upgraded?
On the Emu patch, it that an indication that USB class 2 audio (async audio at 176/192) is happening or is it proprietary?
