| PC Based Computer music servers, crossovers, and equalization |
#1411 | |||
![]() Quote:
![]() BTW, should be fine. The HDD is much more than enough for the OS & software, but of course it's definitely way too small for any serious local music storage.
#1412 |
Thanks for the offer.
Tried all different versions of Fedora and Ubuntu, both CD-Rom media and USB stick. I used newly created CDROMs as well as ones that worked without a problem when I installed Linux on 5 year old laptops. With Fedora I'd get a "Kernel panic" message then the install would fail. There appears to be an active bug for Fedora related to the processor (Via S3). With Ubuntu I kept getting consistent fails on installing the OS to the external USB disk drive (Seagate 250GB). I spent so much time trying to get it to work I've decided to move to different hardware to get around the problem. |
#1413 | ||
Or perhaps some other distribution (maybe DSL? never tried myself...) more specifically oriented toward small/dedicated/embedded systems. That said, you may try installing a very minimal system to the external HDD from another machine and then move it to the VIA. Of course, make sure to choose the right kernel... About failures. Installing to a removable USB HDD is a somewhat "esotic" setup. Performance-wise it is not a very good idea... and may be the source of your troubles, too. The device "names" for the disk may change during the installation process, and that may explain your failures.
#1414 | ||
#1415 | ||
what kind of error do you get when trying to boot it? at which step does it sops? Then, the obvious (though at times overlooked) questions:
most modern desktop distributions by default installs kernels which are optimized for today's "big iron" desktop (and laptop) architectures & CPUs (i686+ and/or amd64). Such optimized kernels may NOT run at all on any "smaller"/older, "generic" i386 or even Pentium (i586) compatible hardware. If you install on a different machine than your target, you have to manually select (or install after the installation but of course still on the "install" machine) a kernel compatible with the "target" architecture.
#1416 |
You can also give openSUSE a try. The last version works like a rocket, it's quite impressive.
Any solution is a compromise. |
#1417 |
UnixMan (and others)
Here are the specs of the mini-PC I bought. If you guys think there is a Linux distro that is more likely to work with this hardware, please let me know. Processor: Via Low Power C3/Eden Processor at 800Mhz Chipset: VIA VT-133 for EPIA (North / South) System Memory: 512MB Memory 1 x Slots availble Video: 64 bit 2D/3D graphic engine and video accelerator , 1280x1024 16 bit color or 1024x768 32 bit color Audio: 3D sound system complies with PC98 audio specifications/Audio-out and Mic-in. LAN: Built-in high speed ethernet 10/100Mbps LAN controller USB: Integrated 4 independent OHCI controller supporting USB 1.1 ports HardDrive: Ultra DMA 33/66/100 IDE Connector Hard Drive Adaptors: IDE to CF -II Adaptor with Cable Mounted on the IDE Slot , A CF Card is not included |
#1418 | ||
You may also look around to see if there is any distro which have been designed specifically for platforms like yours (nowday there is a distro for just about anything... Try googling for something like "VIA VT-133 C3/Eden EPIA Linux" (without quotes, of course). You'll almost surely find plenty of results... and likely something useful, too.
#1419 | |
Little bit of googling and:
Building a Mini 'Quieter-than-a-Whisper' Linux PC | silentpcreview.com Quote:
I would also suggest that trying to install and boot from an external usb harddrive is likely to cause problems, especially with an older system. Why do you need to use one? EDIT: ahh unixman... beat me to it.. Last edited by Theo404; 21st November 2009 at 10:40 PM. |
#1420 |
UnixMan, Theo404, and ratza
Thanks for your advice and interest. I decided to purchase the 2nd hand Intel Pentium box I described in earlier posts. Fedora installed without a hitch within 30 minutes. I now have a working Linux system that recognises my RME sound card. I think my error was persisting with hardware that wasn't up to the task. Cheers. |
| Page generated in 0.15167 seconds (79.97% PHP - 20.03% MySQL) with 11 queries |
