| PC Based Computer music servers, crossovers, and equalization |
#1031 |
People who tried "ecasx" based on ecasound are reporting good results.
::: Squeezebox Touch Toolbox and more ::: by soundcheck |
#1032 | |
M2N68-VM and even though the Nvidia drivers for Linux are marginal they do work. An earlier version of this was used for the LinuxMCE media player platform. However my interest now is a much lighter weight platform (no fans or other moving parts) for audio only. For AV I would use the Popcorn Hour since it does everything and is an almost open Linux Platform.
Demian Martin Product Design Services |
#1033 | |
#1034 |
there are multiple asynchronous (buffered) steps between data in memory and serial audio data out, eg device memory via dma, shift register parallel->serial and so on. Unless your system is so slow that it just can't keep up with a 44.1 or 192khz data out, causing buffer under-runs, then jitter etc here is not an issue, IMHO.
Also, I would think having a cpu frequently go into sleep mode, and then wake up, which radically changes it's power consumption, and clock speed, would generate quite a bit of (RF, psu) noise. |
#1035 | |
Interesting board! THX Would be nice to hear if HDMI-AUDIO - 8*Multichannel LPCM also works with this board.
#1036 | |
#1037 |
Hi there.
FYI: I just learned that after 1.5 years of neglecting a focused maintenance ( was more a sporadic look into it thing) of the realtime kernel patch Th.Gleixner and Ingo Molnar ( the kernel scheduler gurus) sat down to port the linux-rt patch properly to 2.6.29. http://lkml.org/lkml/2009/3/25/480 Let see. I am just trying to get the 2.6.29-rt1 kernel compiled. ![]() That'll mean of course that even Ubuntu Jaunty (2.6.28) won't show up with this kernel. Cheers
#1038 |
Also for ATI we have the radeonhd driver now. Open source!
Works very well, awaiting 3D support. |
#1039 |
You can find how to convert APE files on Linux on my web page dedicated to Linux tips and tricks. In short - use K3B. http://www.starlett.com/~web5_macgur...nd_tricks.html If you have any other question(s) regarding Linux - please let me know. |
#1040 | |
I do find these conspiracy theories and suggestions that the PC might be altering your sound behind your back to be quite dull It should not be too hard to use the digital output on your card and to literally record the output from your two ways of playing back your audio. I would *expect* you to find that the two digital streams are identical (you may need to trim and offset them if you don't have a bit perfect record/playback synchronisation method) If you don't find this then you need to analyse the PC software side until you find out why the digital data is getting altered. If you find that the digital data is *identical* (which I would expect) then your problem boils down to good old fashioned "my DAC is cr*p" - and for some reason your DAC is behaving differently when fed the same bitstream in. Plenty of good reasons why this might be so, but the point is that it's not a "PC issue", it's a "I need a more robust DAC" issue Good luck Ed W P.S I have used a Jack + Brutefir setup very successfully for nearly 5 years now. Resampling (only for 48Khz tv output) is done using libsamplerate, which in it's latest iteration appears to be very near top of the tree in resampling performance. The jack chain always runs at 44Khz, so no resampling done for typical CD playback. Output is via RME9632 to a passive pre-amp, then on to some Hypex amps. Read more at http://www.duffroomcorrection.com |
