PC Based Computer music servers, crossovers, and equalization
Linux  Audio the way to go!?
Old 2nd May 2008, 06:46 PM   #511
jkeny is offline jkeny  Ireland
Banned
OK, it looks like there are reports of wifi problems with Hardy Heron so I guess I should go back a revision to Gutsy Gibbon?
If it doesn't work I'm not bothered - life is too short for loading drivers, firmware, modules, etc.
I don't think it was a live CD version as I didn't have to burn a CD - just download & install!
Old 2nd May 2008, 11:05 PM   #512
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
I did install ubuntustudio-audio yesterday and the wifi connection icon disappeared
The sound through audacious (44,1KHz: USB-> -ecdesigns-' DI16 ultimate NOS DAC) is clearly better: denser images; more defined high-mids, etc.
There is a feature on audacious, the "buffer time" or something like this that can be selected...any advice? (I have not yet the RAM DISK tweak )
Thanks,
M
"Cascode all thy outputs".
Old 3rd May 2008, 07:57 AM   #513
phofman is offline phofman  Czech Republic
Maxlorenz,
did you install the linux-rt real-time kernel along with the ubuntustudio-audio package? Perhaps the linux-rt kernel has some proprietary wifi drivers missing. If so, did you try installing the linux-restricted-modules-rt package?
Old 3rd May 2008, 08:39 AM   #514
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
That's actually one of the reasons why I am running the ZEN-Kernel.
If there is a patch for a certain problem, ZEN will be months ahead
of mainline kernel of implementing itl and even further ahead of Ubuntu.
If you want to squeeze most out of Linux you need get into it.
Linux still hasn't overcome it's weaknesses. Sometime it's really annoying. Though It's getting better every year.
Old 3rd May 2008, 10:48 AM   #515
soundcheck's Avatar
Hi Max.
Audacious Preferences:
Audio:
Tick Enable "Bypass all of Signal processing if possible"
All buffers as small as possible.
Under Alsa Driver Config - Advanced you can also try to get Buffers
down
Disable Replay Gain under Replay Gain.
You should also turn these Visualization effects off. ( Right Click on the header - Visualization Mode "None"
Under View Disable AutoScroll Songname
You should start it from a terminal with
$ sudo chrt -f 75 audacious
Unfortunately there is still no realtime-option as it is available in
XMMS, which made a big difference.
Perhaps you also try to disable as many plugins as possible.
Otherwise you can also try installing XMMS.
Cheers
Old 3rd May 2008, 12:11 PM   #516
Banned
Hey guys,
installed Wubi, and this is more like it - Wifi works out of the box - RhythmBox plays & sounds great. Only issues is that it's not a fully realised Linux, I think as it creates a folder within Windows! Still it's a great intro for anybody looking to taste the wonderful world of Linux & see how a real OS is designed & works - no crashes, very speedy, etc
Edit: So from this I conclude that the RT option is missing some essential modules, as stated above, but I don't know what they are!
Old 3rd May 2008, 01:14 PM   #517
soundcheck's Avatar
Max.
No idea why you can't get the RAMdisk to work. This is really not at all
a difficult task.
Lets try again:
$ sudo gnome-terminal
Now you switch to the new terminal, with all the rights you can get on the system:
$ cp /etc/fstab /etc/fstab.orig
$ echo "tmpfs /tmp tmpfs defaults,size=512m 0 0" >> /etc/fstab
Check if it worked:
$ less /etc/fstab
the number gives ramdisk size in MB. Can be half your RAM max.
If it's there:
Reboot
After that you check with
$ mount
if its there.
Alternative:
RAMDISK:
Try is way:
Open a terminal
$cd
$ln -s /dev/shm RAM
$ cd <your_musicdir>
$ cp <your_audiofile.wav> ~/RAM
Now you look for that file in Audacious and play it.
Cheers
Old 3rd May 2008, 04:23 PM   #518
maxlorenz's Avatar
Thanks guys, for all your advices
Soundcheck,
I'll try my best not to disappoint you this time
I read your post about XMMS not being fully supported for now on... (am I wrong?) I will try it anyway for the real time option.
Phofman,
Ubuntustudio-audio came with linux-rt kernel, as far as I remember...
I did thought about installing another linux-rt, but feared of a conflict of some kind (apart the "restricted" sound dangerous to me! )
I'm a total ignorant, you know...
M
Old 3rd May 2008, 05:32 PM   #519
I do not think linux-rt has a different set of modules than the regular -generic kernel. Of course, it is highly likely the restricted-modules package for the regular kernel is installed by default, whereas you have to install linux-restricted-modules-rt manually. As for its name "restricted" - it contains modules with non-GPL licences (e.g. nvidia, atheros wifi etc. - for details see http://packages.ubuntu.com/hardy/i38...16-rt/filelist ) There is no need to worry about the word "restricted".
Linux is no woodoo and there is no need to make one of it.
Old 3rd May 2008, 07:30 PM   #520
maxlorenz's Avatar
Linux  Audio the way to go!?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
