PC Based Computer music servers, crossovers, and equalization
Linux  Audio the way to go!?
Old 22nd September 2013, 04:16 PM   #2141
phofman is offline phofman  Czech Republic
Originally Posted by soundcheck View Post
Non of your answers refers to my question btw.
Sure they do. The CPU load of resampling causes the XRUNs you are complaining about, I have experienced that many times.
Old 23rd September 2013, 09:59 AM   #2142
Pulseaudio with LD_PRELOADing libsoxr-lsr | Blog IVITERA a.s.
Just like I said.
Old 23rd September 2013, 10:47 AM   #2143
MrSlim is offline MrSlim  Canada
No idea.
I do want to use it as generic desktop system. As a (rather) normal user.
And I'm also aware that there are applications ( also e.g. MPD ), which can
directly access Alsa.
I just wanted to use Rythmbox out of the box. Because it is well integrated into the environment. And certain plugins (e.g. coverart browser) make that
player acceptable to me. ( What I can not say about MPD)
What sucks is pulseaudio and the whole gstreamer jungle.
OK. Nothing new. We were at this point 5 years ago.
Anyhow. With the right prioritiy setting I got a rather acceptable resampling to 96khz (@23%!! CPU load on an i5) going.
Let's see, perhaps I find an answer to the "passthrough" subject, which is supposed to include automatic samplerate switching.
Instead of Ubuntu, try Lubuntu, they pulled Pulse audio out. There's a version called Lubuntu lxle that they have based on the LTS release of Ubuntu. The base Lubuntu is quite basic, but lxle is nicely featured and quite complete from a desktop application perspective. Using LXDE vs Gnome(or Unity or whatever they are calling it) improves performance on older machines....
Old 25th September 2013, 08:40 AM   #2144
soundcheck is offline soundcheck  Germany
I tried Lubuntu, Kubuntu, Xubuntu, Studio, Mint, Fedora, Arch, Gentoo .....
.... to realize, that the best bet -- for my purposes -- is a basic Ubuntu along with some rather minor modifications.
What counts first of all is size in terms of market share and related to size community support.
Derivates usually fall short on support, features and show integration
issues. You'll end up spending more time on hacking then using the
system.
I have Saucy installed now and I'm quite happy.
I'm getting used to Rythmbox with the all its plugins - the cover art browser in particular. It's not perfect, but it works.
I'm running speex-5 now with pulseaudio.
I can even run Windows apps like DBpoweramp and Office with Wine1.6 nowadays.
SMPlayer is my video player of choice btw.
I use ARCH-Arm on my RPi network player btw.
Cheers
Old 25th September 2013, 09:17 AM   #2145
Originally Posted by phofman View Post
Yep. You said it.
Where do you put the LD_PRELOAD entry to have it applied at system start ??
Old 25th September 2013, 09:28 AM   #2146
I did not, just tested running pulseaudio from command line. I guess it will be on each distribution different. Just search where pulseaudio server is called on your machine - either at startup scripts for system-wide or autostart when user-based. On my home mate mint it was I think in pulseaudio-kde script.
I am talking to Rob, the author of libsoxr, about the clicks. He is very helpful.
Old 25th September 2013, 10:40 AM   #2147
I'm trying for a while to figure out how this pulseaudio gets started.
Not any Wiki seems to be up2date.
Autostart:
/etc/xdg/autostart/pulseaudio-kde.desktop or
/etc/xdg/autostart/pulseaudio.desktop
These files call
/usr/bin/start-pulseaudio-[kde||X11]
which just seem to load some PA modules.
However. By running pactl PA seems to be started automatically.
That might explain why taking PA out of "autostart" won't stop it from autostart at boot.
Then there are SysVinit AND Upstart PA startscripts at /etc/init.d and /etc/init.
But these seem to sit idle. And will only by used if PA is uses as system wide daemon.
Currently the daemon will be started on per user basis, with the particular user ID and permission.
That's why PAM needs to be set up properly for your user to allow realtime prio and nice adjustments.
It's still not working in my case.
??? I'm kind of lost.
Old 25th September 2013, 04:00 PM   #2148
Just figured that pulseaudio respawns several times during boot/login.
And every time it restarts it uses a different daemon.conf and client.conf config file.
I figured that out by defining a different logfile in each of the config files.
Interesting to see is that timidity's starting up PA twice.
What a jungle.
I then removed Timidity.
Guess what:
Code:
-rw------- 1 lightdm lightdm 71262 Sep 25 17:16 pa-client-etc.log
-rw------- 1 klaus   klaus   63239 Sep 25 17:16 pa-client-home.log
-rw------- 1 lightdm lightdm     0 Sep 25 17:15 pa-daemon-etc.log
-rw------- 1 klaus   klaus       0 Sep 25 17:16 pa-daemon-home.log
Now the lightdm login manager starts a session first, probably to be able to issue the login sound. Weired.
Old 25th September 2013, 04:42 PM   #2149
Weired. Maybe not!?!?
Let's try to get the logic right:
There are certain system related sounds or services that require a PA instance running -- before a user logs in.
First it was Timidity, now it's lightdm, since Timidity was removed.
These services are using the generic config files under /etc/pulse and apply their own user id and permissions.
As soon as the user logs in PA needs to be restarted to load the user specific parameters and modules.
At this point PA is issuing pactl commands to load the X11 related PA modules. These pactl commands are executed by the startup script "start-pulseaudio-x11" which gets triggered from "Startup-Applications. pactl restarts automatically the daemon. Restart, because some user specific parameters have to be changed.
At this point user specfic settings will be applyied.
Another finding is that the client.conf overrules the daemon.conf settings.
Hmmh. That's exhausting. That's Linux.
Old 25th September 2013, 05:10 PM   #2150
pguerin is offline pguerin  France
Why using pulseaudio ? It's seems that it resample everything to 48 Khz.
Another thing, I found a real improvement of the sound quality after removing pulseaudio and using ALSA with my M-Audio 1010LT card.
Just my 2 ...
Linux  Audio the way to go!?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
