PC Based Computer music servers, crossovers, and equalization
Linux  Audio the way to go!?
Old 15th February 2013, 10:49 AM   #2061
mfaughn is offline mfaughn  United States
Originally Posted by mfaughn View Post
digital 2 or 3-way stereo crossover, filtering, room correction, etc. before we ever touch produce an analog signal...and then to produce analog signals but bi/tri-amping.
What I mean is a software / hardware solution. I've been doing a bit of reading about what the Windows monkeys are doing and it seems to typically involve at least two of these three adjectives: complicated, expensive, unstable, technically inadequate (e.g. using multiple DACs with no regard to clock syncronization).
Old 15th February 2013, 02:29 PM   #2062
phofman is offline phofman  Czech Republic
in linux relatively too
expensive
ok, free in linux
unstable
if you script your well-tested equalising chain to start reliably, than I would say stable
That is a hardware issue, common to all OSes. In linux it is easier to merge soundcards though.
Old 15th February 2013, 02:37 PM   #2063
Onvinyl is online now Onvinyl
Onvinyl's Avatar
Woldn't it be possible to use one of the mulichannel dac projects here on diyaudio for this purpose?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 15th February 2013, 02:40 PM   #2064
Rüdiger
IMO multichannel output is no major problem in linux, there are numerous multichannel soundcards, USB adaptive DACs can be safely merged using the multi alsa plugin (the major linux advantage), etc.
Old 16th February 2013, 02:09 PM   #2065
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
Hi folks.
I'm playing around with a tiny Android 4.1.1 device.
I just hooked up my good old EMU 0404 USB to it.
It was immediately recognized.
The problem is now that I'd need amixer (alsa-utils) to set the samplerate.
It seems that nobody is considering alsa-utils a useful package for Android.
Question: Is it possible to set the driver parameters that are usually set via amixer also diretcly via /proc/asound ??
Thx
Cheers
Old 16th February 2013, 02:38 PM   #2066
qusp is offline qusp  Australia
qusp's Avatar
using multiple devices as a composite audio device (called aggregate audio device) has been possible in mac OS for many years, or you speak of an advantage vs windows?
Old 16th February 2013, 03:53 PM   #2067
Yes, I see windows users fighting such setup all the time.
Old 16th February 2013, 06:43 PM   #2068
MrSlim is offline MrSlim  Canada
Originally Posted by soundcheck View Post
Hi folks.
Thx
Cheers
This thread: [android-porting] ALSA on x86 - No sound may hold some clues for you. They mention alsa_mixer and saving the settings in /system/etc/alsa_config.
Old 16th February 2013, 06:59 PM   #2069
Hi folks.
Thx
Cheers
Old 17th February 2013, 11:54 AM   #2070
Well, after a bit more poking around I'm tempted to just get a Delta 1010 and have a go at it. I'm also thinking that something like the nanoDigi into a Buffalo-III would suit.
Linux  Audio the way to go!?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
