PC Based Computer music servers, crossovers, and equalization
Linux  Audio the way to go!?
Old 11th March 2009, 02:13 PM   #1001
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
Originally posted by anbello
What do you thing of the solution proposed on post #988?
Is it not interesting to you or not enough well explained?
If someone is interested i can open a new thread to talk about this stuff.
[/B]
yes! Do it, please.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 11th March 2009, 03:38 PM   #1002
soundcheck is offline soundcheck  Germany
Hi folks.
I just installed a Linux MINT6, it is based on Ubuntu 8.10. Some time ago somebody brought it up over here.
The community acceptance is quite high. On distrowatch.com they are already on rank 3, right after Ubuntu and Suse.
No wonder why. Look and feel is really nice.
To me it looks much more professional (serious) then a stock Ubuntu. Under the hood you'll find of course the same stuff as you'd find it in Ubuntu.
rt-kernel is also available.
If you look for a new fresh look and feel - give it a try.
Cheers
Old 11th March 2009, 04:20 PM   #1003
anbello is offline anbello  Italy
anbello's Avatar
From UnixMan:
yes! Do it, please.
I started a new thread here
Ciao
Andrea
Old 11th March 2009, 06:24 PM   #1004
Telstar is offline Telstar  Italy
Originally posted by UnixMan
I think there are many other people interested about that... (me, for one! ) so IMHO better open another thread instead.
I posted it here:
http://www.diyaudio.com/forums/showt...00#post1770500
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 12th March 2009, 08:46 PM   #1005
Onvinyl is offline Onvinyl
Onvinyl's Avatar
I have problems with my real time ubuntu studio installation. (8.04) When running mpd in real time mode, the main terminal gets flooded with error warnings, and the audio has a lot of dropouts and sounds bad. Plus, as already mentioned, I can't play radiostreams, but this is probably another problem.
This is not the worlds cutest error description, but maybe someone has an idea?
Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog
Old 12th March 2009, 09:29 PM   #1006
You should think about upgrading to 8.10. Makes life easier.
Old 12th March 2009, 09:46 PM   #1007
Onvinyl's Avatar
I'm not familiar with the upgrading process. Do you think, it will solve my problems? Will the upgrade leave newer software releases intact (mpd, alsa, sox etc.pp.)? Will I have to reconfigure my network (vncserver, samba etc.)?
Will it leave the customizing intact? (No xwindow at startup, for instance)
It was a whole lot of work to set it up. Plug & Swear!
Rüdiger
Old 12th March 2009, 10:50 PM   #1008
Usually the upgrade is easy going.
However:
Make yourself familiar with the backup and restore routine before you start your upgrade. This is for sure more complex and risky then the upgrade itself.
Cheers
Old 12th March 2009, 11:22 PM   #1009
phofman is offline phofman  Czech Republic
Onvinyl,
please elaborate more. What error messages are you getting? What is your soundcard? What are your PC parameters? What is your audio usage scenario (playback or recording/mastering too)?
I have experienced problems with sound drivers/hardware behaving differently in the ubuntu studio RT kernel compared to the generic kernel in the same ubuntu version. Unless really needing low latency, I personally would not use it. I am writing this on ubuntu studio with the generic kernel.
http://mailman.alsa-project.org/pipe...ay/008096.html
http://mailman.alsa-project.org/pipe...il/007614.html
http://mailman.alsa-project.org/pipe...ay/007624.html
Old 22nd March 2009, 07:24 PM   #1010
Hi folks.
I lust started up an Ecasound Wiki.
http://www.diyaudio.com/wiki/index.p...Audio+Ecasound
I try to avoid redundant information. You'll find plenty of stuff and examples on the ecasound homepages or manpages.
For now I outline how to compile it from sources, how to get it to work with MPD
and how to get it remote controlled e.g. volume control via TCP and netcat.
Cheers
Linux  Audio the way to go!?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
