PC Based Computer music servers, crossovers, and equalization
A how to for a PC XO.
Old 6th January 2009, 12:59 AM   #1001
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Originally posted by BerntR Audiolense is the only multichannel solution that addresses all aspects of driver integration, speaker integration and bass management for the complete speaker setup.
That isn't strictly true. Just to be clear, Acourate is more hands on but will do everything Audiolense does and more.
Old 6th January 2009, 07:04 AM   #1002
King Nothing is offline King Nothing  United States
shin
I was thinking about latency, FIR, and blu HD content. What do you think about Koons CUDA fir? with the massive performance CUDA gives over traditional processors I think it could be possible to use FIR in realtime with little delay. Or I am way off base :|
Old 6th January 2009, 12:49 PM   #1003
ShinOBIWAN's Avatar
Originally posted by King Nothing
shin
It needs a lot of work before it could supplant the Acourate method. Now if it was a GPU powered convolution engine to host Acourate generated filters and was useable as a VST plugin then it would open it up whole lot more. I suspect this is impossible with the way HDMI works but that sort of setup would be exactly what we have now but with much lower latency. This is an advancement.
As it stands your trading an awful lot of power just for the latency drop. Its an innovative achievement but not a way forward for me.
Old 6th January 2009, 01:47 PM   #1004
Sonopanic is offline Sonopanic  Germany
Wow, this forum is amazing. All the fast experts...
I knew a few things about accourate and stereosetups and have
a good mic.
What steps i have to do for multichannel ?
Is there a manual ?
And the other question :
The M-Audio 1010LT is cheap, is there any no gos with this card ?
Last question so far :
When i use my MainPC for the first steps, i have 3GHz C2D CPU.
Is this enough power to do the convolution and the playback
in one machine ?
Thank you for all the help.
Old 6th January 2009, 01:53 PM   #1005
ackcheng is offline ackcheng  Hong Kong
Send a message via ICQ to ackcheng
When you do stereosetups with accourate, you will noticed that you work with one channel and then the other. Setting up multichallel is just the same
Old 6th January 2009, 02:03 PM   #1006
BerntR is offline BerntR  Norway
This seems more vague than clear to me.
What is it exactly that Acourate does that Audiolense doesn't? And how does that impact the end result?
achengs description of making multichannel correction with Acourate is IMO to the point. With Audiolense you do each operation one time only, and then it's done for every speaker and driver in the setup. I stand by what I said above.
Best Regards,
Juice Hifi
Old 6th January 2009, 02:05 PM   #1007
Frode is offline Frode  Norway
I'm struggelig to get in to PC-based XO/DRC. I've used Audiolense to make a filter, but have big problems when I try to use the filter. The soundcard is a ESI U46XL soundcard, I have and computers with both Vista and XP. I've tried many different setups, but most of the time I only get sound in 2 channels. The only thing that has worked so far, is the internal player in Bidule(on a Vista PC). This is not very user friendly, so today I've looked into Console on my old XP PC. But I don't understand how to get the signal into Console. This is what I've done so far:
My soundcard has something called DirectWIRE, and the control panel looks like this:
Can anyone help me with this?
Frode
Old 6th January 2009, 10:58 PM   #1008
ShinOBIWAN's Avatar
I don't see the confusion with what I said previously.
You must have missed my post on the last page:
http://www.diyaudio.com/forums/showt...52#post1704452
The open ended nature of Acourate is like a calculator with functions that allow an almost limitless scope of filter manipulation. Uli knows best how to bend his software to creative ends but one example where this went to furthering the sound was matching the pulse responses of the left and right channels after room correctionie. they both perform close to identical in the time domain. Can Audiolense provide functionality to do this?
Old 7th January 2009, 12:01 AM   #1009
ShinOBIWAN's Avatar
I've downgraded, yep downgraded my audio interface. Previously I used a Lynx Aurora 16 DAC but the fall of the pound against the dollar now means this unit is rather expensive over here. A good time to sell then. Pure luck really but in this case I made quite a bit over my original second hand purchase price.
With the money I was in two minds as to whether to go really crazy and buy some very highend converters such as Universal Audio, Lavry, Mytek or be conservative and consolidate the money into other parts of the system. The crunch came this weekend after I compared a Mytek 8x192 to an old favourite of mine(had one before) the RME fireface 800 in a pro audio music store. I was surprised, happy and yet slightly disappointed all that same time. I think the differences we perceive in converters can often be down placebo or whatever else you like to call it because this little demonstration quickly reminded me that once you hit a good level then things start to get expensive very quickly with almost imperceivable sonic gains. In short I was straining to hear a significant difference between the almost legendary Mytek vs. the relatively affordable RME.
I already had Apogee DA16x, another good convertor, a couple of years ago and came to the same conclusion so I shouldn't have expected much change but you keep look for that upgrade that will take your system higher than before but in this case it wasn't the DACs'. Seems the ones in the RME are pretty darn good.
On the flipside of the my fortitous gain with the Lynx from the downturn of our economy I found out that the Euro was beating the hell out of the pound and goods from the EU were accordingly more expensive. Guess what? RME is manufactured in Germany. What was once an ~800 interface was now 950, quite a leap for the same product. But I lucked out once again and found a second hand model on ebay for 630. That's more like it.
RME is no slouch so don't take this too literally but my thought of the day is don't obsess too much over DAC's if the unit your looking at is well engineered. You don't have to spend a fortune(however much you want to ) to get top end results.
Also be frugal and always buy second hand if possible. I'm finding great saving doing this and you can put that into more important things besides audio.
Old 7th January 2009, 12:48 AM   #1010
Even the first release of Audiolense did that.
At least in principle . Quite a few bugs has been removed since the beta.
The only requirement is to apply a group delay correction procedure such that the left and right speaker have basically the same frequency response inside the subject time domain window after correction. The top end has a particularly huge impact on the impulse response close-up and have to be corrected all the way to obtain that kind of symmetry.
I have attached a simulated response after correction of L+R speaker together with the target response.
The simulation shown is simply the original measurement convolved with the correction filters. No other filtering applied.
The correction procedure used is an overkill procedure that performs a full time & frequency domain correction by the direct sound approach. And without any conditioning of the measurement. This procedure corrects every tooth in the comb filter with up to 50 dB. So a one-eared person with the head clamped in a fixed position, full climate control etc etc.... can enjoy perfect sound.
Seriously, this procedure is not for real life use. Its usefullness is limited to testing the correction capabilities of Audiolense. The RMS of the corrected IR (not shown here) drops to -60 dB right away and the room decay is attenuated down to about -70dB shortly after. This is probably a big enough correction muscle for most user requirements in most practical situations.
Huge amounts of Group Delay (time domain) correction seem to have merits in the very deep bass in some of the setups I've visited. One way of seeing this is as having a *very* simultaneous sound arrival. Another way is a method for cancelling boundary effects.
I have done some measurements that indicate that a typical, medium moderate group delay correction of audiolense supresses the room decay with about 4-6 dB. I would expect to see bigger drops in the deep bass when huge amounts of group delay correction is called for and applied.
PS: The simulated response after correction shown in the thumbnail is generated from a sample measurement that is included in the Audiolense demo. So anyone who wishes can download the demo and try this out for themselves.
Best Regards,
Juice Hifi
A how to for a PC XO.Hide this!Advertise here!
